hungjury wrote on Thursday, February 10, 2011:
I am using the PIC24 Demo Application with the C30 Compiler. I have V6.1.1 of the RTOS.
I have 2 questions:
1. The demo doesn’t compile. I get the following:
Warning: linker script did not specify CRT0_STARTUP file, default for this device: crt0_standard.o
Warning: linker script did not specify CRT1_STARTUP file, default for this device: crt1_standard.o
Error: A heap is required, but has not been specified
Where do I look for the two ctr0/1 file definitions?
Where do I define the heap? Normally these are specified in the build options dialog box (heap and min stack size). Is there another way this is being handled in the demo project (obviously not, hence the error). What do I set these to?
2. Sorry, but I am a newb on FreeRTOS. I figure that the RTOS must be using system resources, for example a counter/timer for the tick timer. Does the RTOS use a resource and if it does, how do I find the documentation on which resources it is using?
Thanks for the help!
