nobody wrote on Friday, July 21, 2006:
Hello Ben,
I tried to understand your report of 2006-01-27, after being notified of it by Richard.
I assume you use the microchip C18 compiler, since it isn´t specified in the post.
I fail to see the supposed bug, since FSR1 is _never_ changed in 2 operations during normal function calling.
The compiler uses POSTINC1 and POSTDEC1 registers, which properly handle overflow of the lower byte of FSR1 into the high byte. The PIC18C reference manual says: "Incrementing or decrementing an FSR affects all 12 bits. That is, when FSRnL overflows from an increment, FSRnH will be incremented automatically."
FSR1 is the stack pointer, points to first UNused location
FSR1L: adres 0xFE1
FSR1H: adres 0xFE2
PREINC: adres 0xFE4
POSTDEC: adres 0xFE5
POSTINC: adres 0xFE6
FSR2 is the frame pointer
FSR2H: adres 0xFDA
FSR2L: adres 0xFD9
Function call:
140: vStartIntegerMathTasks( tskIDLE_PRIORITY );
3DA8 6AE6 CLRF 0xfe6, ACCESS // Push parameter (with value: 0) on the stack through postinc1
3DAA EC88 CALL 0x3b10, 0 // Call function
3DAC F01D NOP
3DAE 52E5 MOVF 0xfe5, F, ACCESS // Discard parameter from stack hrough postdec1.
// FSR1 is restored to value before calling the functions.
Overhead inside a function:
On entering function:
Push old frame pointer FSR2 on stack and set FSR2 to FSR1
434C CFD9 MOVFF 0xfd9, 0xfe6 // Push FSR2L on stack and increase FSR1
434E FFE6 NOP // through indirect adressing through postinc1
4350 CFDA MOVFF 0xfda, 0xfe6 // Push FSR2H on stack and increase FSR1
4352 FFE6 NOP // though indirect adressing through postinc1
4354 CFE1 MOVFF 0xfe1, 0xfd9 // Copy FSR1L to FRS2L, FSR1 not modified
4356 FFD9 NOP
4358 CFE2 MOVFF 0xfe2, 0xfda // Copy FSR1H to FRS2H, FSR1 not modified
435A FFDA NOP
On exit function:
Restore old frame pointer from stack
3F80 52E5 MOVF 0xfe5, F, ACCESS // Discard unused top of stack through postdec1
3F82 CFE5 MOVFF 0xfe5, 0xfda // Restore FSR2H through postdec1
3F84 FFDA NOP
3F86 CFE7 MOVFF 0xfe7, 0xfd9 // Restore FSR2L from IND1, do not decrement pointer!
3F88 FFD9 NOP
3F8A 0012 RETURN 0
FSR1 (FSR1L + FSR1H) are always consistent during normal function calling.
If there would be a problem it would be in FSR2, since FSR2 IS saved and restored from the stack in 2 steps.
However, an inconsistent FSR2 (through an interrupt in between the 2 assignments) is never used in the interrupt context, since the interrupt function immediately sets a new frame pointer. Storage of an inconsistent FSR2 on the stack is no problem. On leaving the interrupt routine, the inconsistent FSR2L and FSR2H pair have been restored and the next instruction (remember where we were?) restores FSR2 to a consistent state.
Maybe what you are referring to is the FSR1 save and restore by the FreeRTOS framework? since this does take 2 instructions.
This is also safe since through a taskswitch, interrupts are always off:
portSAVE_CONTEXT clears the global interrupt pretty early, and interrupts aren´t enabled again until exiting portRESTORE_CONTEXT()
I don´t think there is any need to change anything.
Paul van der Hulst
