xintersecty wrote on Saturday, October 17, 2009:
I have been working on porting the example demo application from the Explorer 16 development board to the Explorer 16 starter kit. So far I have isolated all the needed bits, and changed to the main loop to a simple LET strobe program. I had followed the instructions on the freeRTOS website on ports.
So far so good, but I am having a major problem with the processor symbols.
> Make: The target "C:\Documents and
> Settings\Owner.bclaptop\My
> Documents\ovation\Common\Minimal\crflash.o"
> is up to date. Make: The target
> "C:\Documents and
> Documents\ovation\PIC24_MPLAB\ParTest\ParTest.o"
> is out of date. Executing:
> "C:\Microchip Starter Kits\PIC24F
> Starter Kit 1\MPLAB
> C30\bin\pic30-gcc.exe"
> -mcpu=24FJ256GB106 -x c -c "ParTest.c" -o"ParTest.o" -I"."
> -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\Source\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\PIC24_MPLAB" -I"…\…\PIC24_MPLAB" -I"…\…\…\PIC24_MPLAB" -I"…\…\…\…\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -D__DEBUG -fno-omit-frame-pointer -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -O1 -fno-schedule-insns -fno-schedule-insns2 ParTest.c: In function ‘vParTestInitialise’:
> ParTest.c:65: error: ‘TRISA’
> undeclared (first use in this
> function) ParTest.c:65: error: (Each
> undeclared identifier is reported only
> once ParTest.c:65: error: for each
> function it appears in.) ParTest.c:66:
> error: ‘PORTA’ undeclared (first use
> in this function) ParTest.c: In
> function ‘vParTestSetLED’:
> ParTest.c:82: error: ‘PORTA’
> function) ParTest.c: In function
> ‘vParTestToggleLED’: ParTest.c:107:
> in this function) Halting build on
> first failure as requested.
> ----------------------------------------------- Debug build of project `C:\Documents
> and Settings\Owner.bclaptop\My
> Documents\ovation\PIC24_MPLAB\RTOSDemo_PIC24.mcp’
> failed. Preprocessor symbol `__DEBUG’
> is defined. Target debug platform is
> `__MPLAB_DEBUGGER_SKDE=1’. Debug
> platform options are: `__ICD2RAM=1’.
> Fri Oct 16 10:44:35 2009
I changed the linker script from the p24FJ128GA010.gld script to the p24HJ256GP210.gld as the PIC24FJ256GB106 chip is on the starter board.
So here is my problem, ( I am sure it will not be my last problem
): I can not figure out how to get the development environment to understand where to find the symbols using the new script. So this is really an IDE/compiler problem.
Thanks in advance!
