Can anybody explain why the delivery of file blocks is not sequential?
[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=283, Size=2048
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 7
[INFO] [OtaConfig] [executeHandler:2939] Current State=[WaitingForFileBlock], Event=[ReceivedFileBlock], New state=[WaitingForFileBlock]
[INFO] [OtaTask] [MqttDataCallback:738] Received data message callback, size 2074.[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=282, Size=2048
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 6
[INFO] [MqttAgent] [MqttAgentTask_Publish:965] Sent PUBLISH packet to broker $aws/things/XXXXXX/streams/XXXXXXXXXXXXXXXXXXXXXXXXXX/get/cbor.[INFO] [OtaConfig] [requestFileBlock_Mqtt:1166] Published to MQTT topic to request the next block: topic=$aws/things/XXXXXX/streams/XXXXXXXXXXXXXXXXXXXXXXXXXX/get/cbor.
[INFO] [OtaConfig] [executeHandler:2939] Current State=[WaitingForFileBlock], Event=[RequestFileBlock], New state=[WaitingForFileBlock]
[INFO] [OtaTask] [MqttDataCallback:738] Received data message callback, size 2074.[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=284, Size=2048
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 5
[INFO] [OtaTask] [MqttDataCallback:738] Received data message callback, size 2074.[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=285, Size=2048
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 4
[INFO] [OtaTask] [MqttDataCallback:738] Received data message callback, size 2074.[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=287, Size=2048
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 3
[INFO] [OtaTask] [MqttDataCallback:738] Received data message callback, size 2074.[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=286, Size=2048
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 2
[INFO] [OtaTask] [OtaThread:342] Received: 288 Queued: 288 Processed: 288 Dropped: 0
[INFO] [OtaTask] [MqttDataCallback:738] Received data message callback, size 1750.[INFO] [OtaConfig] [validateDataBlock:2535] Received valid file block: Block index=289, Size=1724
[INFO] [OtaConfig] [ingestDataBlockCleanup:2771] Number of blocks remaining: 1
