mishung wrote on Friday, February 10, 2017:
Hello, I am running in bit of a memory allocation problem here. I am using a FreeRTOS on xmega32d4, the compiler I am using is AVR-GCC, optimisation set to max (-O3).
Even without any custom tasks created, 528 bytes from stack is being used.
*185 bytes get allocated in task.c line 3134 **
pxStack=(StackType_t)pvPortMallocAligned((((size_t)usStackDepth)sizeof(StackType_t)),puxStackBuffer);
37 bytes get allocated in task.c line 3140
pxNewTCB=(TCB_t)pvPortMalloc(sizeof(TCB_t));
306 bytes get allocated in task.c line 1565
xReturn = xTimerCreateTimerTask();
The timer task is configured to allocate minimal stack size which is set to 185 bytes so why does it take 306 bytes?
Also, whenever I create a task, it takes more stack space from heap than it should. Every task takes exactly 37 bytes more than what I allocate for it.
Here are my OS settings:
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#include <avr/io.h>
#define configCALL_STACK_SIZE 20
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
* See http://www.freertos.org/a00110.html.
/* define priority level names*/
#define PRIORITY_LOW (tskIDLE_PRIORITY+1)
#define PRIORITY_MED (tskIDLE_PRIORITY+2)
#define PRIORITY_HI (tskIDLE_PRIORITY+3)
#define configMAX_PRIORITIES 4
/* config */
#define configUSE_PREEMPTION 0
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ (F_CPU)
#define configTICK_RATE_HZ ((TickType_t)1000)
#define configMINIMAL_STACK_SIZE (185U)
#define configTOTAL_HEAP_SIZE ((size_t)(1400))
#define configMAX_TASK_NAME_LEN 8
#define configUSE_16_BIT_TICKS 1
#define configUSE_TASK_NOTIFICATIONS 0
#define configUSE_MUTEXES 1
#define configUSE_RECURSIVE_MUTEXES 0
#define configUSE_COUNTING_SEMAPHORES 0
#define configQUEUE_REGISTRY_SIZE 1
#define configUSE_QUEUE_SETS 0
#define configUSE_TIME_SLICING 1
#define configUSE_NEWLIB_REENTRANT 0
#define configENABLE_BACKWARD_COMPATIBILITY 0
#define configNUM_THREAD_LOCAL_STORAGE_POINTERS 0
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES 2
/* XMEGA port specific configuration */
/* for info see ... */
#define configPORT_DISABLE_ALL_INTERRUPTS_DURING_CONTEXT_SWITCH 0
#define configPORT_SAVE_RAMPZ_ON_CONTEXT_SWITCH 0 //is zero for small MCUs
#define configPORT_TICK_TIMER D0 //tick timer
#define configPORT_TICK_TIMER_INTCTRLA_ADDRESS 0x0906 //tick timer INTCTRLA address
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 0
#define INCLUDE_vTaskDelete 1
#define INCLUDE_xResumeFromISR 0
#define INCLUDE_vTaskDelayUntil 0
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 0
#define INCLUDE_xTaskGetCurrentTaskHandle 0
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define INCLUDE_xTaskGetIdleTaskHandle 0
#define INCLUDE_xTimerGetTimerDaemonTaskHandle 0
#define INCLUDE_pcTaskGetTaskName 0
#define INCLUDE_eTaskGetState 1
#define INCLUDE_xEventGroupSetBitFromISR 0
#define INCLUDE_xTimerPendFunctionCall 0
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY 1
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH configMINIMAL_STACK_SIZE
