3 threads: A @ priority 3, B @2, C @1, one interrupt D, system tick is 1ms
All threads takes only a small fraction of time to run most time.
A ran for a fraction of ms and wait for the semaphore to be given by D, so the next thread will run
B ran for a fraction of ms and use vTaskDelay(1) to allow the next thread to run
C ran for a fraction of ms and called vTaskDelay(1)
At this point, 1ms hasn’t passed yet, so will the system enter some idle state until the next tick? If so, is there a way to wake up a specific thread? For example, wake up B and it runs until the next tick, which will be A’s turn again.
(Still no system tick) If D gives the semaphore, will A resume immediately? If so, when the next system tick occurs, I assume A continue since it has the highest priority
The idle task will run at priority 0.
Your code has told B to wait for 1 tick, so that is what it will do. You could run B at priority 0 too, in which case it will share processing with the idle task when A and C are not running. Setting configIDLE_SHOULD_YIELD to 1 in FreeRTOSConfig.h makes the idle task always yield to B straight away if B is not blocked. Alternatively you can make B block on a semaphore instead of vTaskDelay(1) and give the semaphore from the idle hook function but that would seem like overkill.
Yes, if that is what you told it to do, of course. The port you are using will have a YIELD_FROM_ISR or END_SWITCHING_ISR macro to ensure it happens. Both macros do the same thing, different ports just use different names for some reason. Look at the examples that come with your port. http://www.freertos.org/a00090.html
Yes. The highest priority task that is not blocked or suspended will always run, and time slice with other tasks that have the same priority and are also not blocked if there are any.
Setting configIDLE_SHOULD_YIELD to 1 ", do you mean “Setting configIDLE_SHOULD_YIELD to 2”, since B has priority of 2
No, configIDLE_SHOULD_YIELD is binary, 1 or 0. I mentioned it in context of running the other task at priority 0 (idle priority). Look it up on http://www.freertos.org/a00110.html
