glenenglish wrote on Thursday, February 22, 2018:
Hi
I read the documentation on the use of setsockopt and the example has the following order- setsockopt is called AFTER the bind
However in your provided code, setsockopt is called BEFORE the bind.
Which is the intended order?
regards
glen english
sample code and order at
https://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/TCP_Networking_Tutorial_TCP_Client_and_Server.html
and extract of TCPServer_t *FreeRTOS_CreateTCPServer( from FreeRTOS_TCP_server.c
xSocket = FreeRTOS_socket( FREERTOS_AF_INET, FREERTOS_SOCK_STREAM, FREERTOS_IPPROTO_TCP );
FreeRTOS_printf( ( "TCP socket on port %d\n", ( int )xPortNumber ) );
if( xSocket != FREERTOS_NO_SOCKET )
xAddress.sin_addr = FreeRTOS_GetIPAddress(); // Single NIC, currently not used
xAddress.sin_port = FreeRTOS_htons( xPortNumber );
FreeRTOS_bind( xSocket, &xAddress, sizeof( xAddress ) );
FreeRTOS_listen( xSocket, pxConfigs[ xIndex ].xBackLog );
FreeRTOS_setsockopt( xSocket, 0, FREERTOS_SO_RCVTIMEO, ( void * ) &xNoTimeout, sizeof( BaseType_t ) );
FreeRTOS_setsockopt( xSocket, 0, FREERTOS_SO_SNDTIMEO, ( void * ) &xNoTimeout, sizeof( BaseType_t ) );
