Hi, I am using MK12DX256VLH5 running on FreeRTOS.
I am trying to generate a 20kHz tone using FTM0 channel 2.
I tried with my code below but doesn’t seem to work.
Is someone able to help to advise if I did any mistake?
Thank you.
void Init_FTM(void)
ftm_config_t ftmConfig
ftm_chnl_pwm_signal_param_t ftmParam;
/* Configure ftm params with frequency 20kHZ */
ftmParam.chnlNumber = (ftm_chnl_t)kFTM_Chnl_2;
ftmParam.level = kFTM_LowTrue;
ftmParam.dutyCyclePercent = 50U;
ftmParam.firstEdgeDelayPercent = 0U;
/* Get FTM Config & Init FTM */
FTM_GetDefaultConfig(&ftmConfig);
ftmConfig.pwmSyncMode = kFTM_HardwareTrigger_0;
FTM_Init(FTM0, &ftmConfig);
FTM_SetupPwm(FTM0, &ftmParam, 1U, kFTM_CenterAlignedPwm, 20000U, kFTM_SystemClock);
FTM_EnableInterrupts(FTM0, kFTM_Chnl_2);
FTM_StartTimer(FTM0, kFTM_SystemClock);
void FTM_0_HANDLER(void)
/* Clear interrupt flag.*/
FTM_ClearStatusFlags(FTM0, kFTM_TimeOverflowFlag);
ftmIsrFlag = true;
int main(void) {
/* Init board hardware. */
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitBootPeripherals();
Init_FTM();
while(1) {
if (ftmIsrFlag)
ftmIsrFlag = false;
printf(" -- ");
