Nuvoton M453: FreeRTOS interrupt stops all tasks
Hi all,
I am using nuvoton M453 mcu with freeRTOS and currently I am stuck in my code that I create 3 tasks; all are running on same priority which works fine but when I want to run 2 tasks from H/W interrupt (a button). All tasks stop working.I also checked the MAX_PRIORTES and MAX_SYSCALL_INTERRUPT_PRIORITY which seems to be ok.I am new in RTOS code so, can anyone share me some example code having tasks call from interrupt and then tasks working after interrupt.
You can wait for a notification in your task and your ISR can send the task notification. The following page contains one such example - RTOS Task Notifications - FreeRTOSā„¢.
Hello @Rajput, welcome to the FreeRTOS community!
Adding to @aggarg’s response, here’s an example approach for your application using task notifications (one of FreeRTOS’s preferred ways to communicate from an ISR) to ā€œwakeā€ two tasks (Task1 and Task2) when a button interrupt occurs. Make sure that the interrupt is set with a priority at or below configMAX_SYSCALL_INTERRUPT_PRIORITY.
/* Global task handles */
TaskHandle_t xTask1Handle = NULL;
TaskHandle_t xTask2Handle = NULL;
TaskHandle_t xTask3Handle = NULL;
void vTask1( void *pvParameters )
    for( ;; )
        // Wait indefinitely for a notification
        ulTaskNotifyTake( pdTRUE, portMAX_DELAY );
        // Notification received: process button event
        //  Task1 logic
void vTask2( void *pvParameters )
    for( ;; )
        // Task2 logic
void vTask3( void *pvParameters )
    for( ;; )
        // Task3 logic
/* Hardware interrupt handler for the button */
void ButtonPress_IRQHandler( void )
    // Clear the interrupt flag (MCU/hardware specific)
    ClearButtonInterruptFlag();
    // Notify Task 1 and Task 2 that the button was pressed
    vTaskNotifyGiveFromISR( xTask1Handle, &xHigherPriorityTaskWoken );
    vTaskNotifyGiveFromISR( xTask2Handle, &xHigherPriorityTaskWoken );
    // Force a context switch if any task was woken up
int main( void )
    // System and hardware initialization
    HardwareInit();
    // Create 3 tasks at the same priority
    xTaskCreate( vTask1, "Task1", configMINIMAL_STACK_SIZE, NULL, 1, &xTask1Handle );
    xTaskCreate( vTask2, "Task2", configMINIMAL_STACK_SIZE, NULL, 1, &xTask2Handle );
    xTaskCreate( vTask3, "Task3", configMINIMAL_STACK_SIZE, NULL, 1, &xTask3Handle );
    // Start the scheduler
    vTaskStartScheduler();
    // Should never reach here.
    for( ;; );
@bhoomrs and @aggarg Thanks for your reply, I will check and update you ASAP.
Hi @bhoomrs,
Thanks for sharing it works fine as I wish and it’s working using without semaphore :+1:
One more thing I will ask you that what is the difference between semaphore and the notification (that you shared me).
Glad it helped!
Task notifications and binary semaphores both serve as synchronization mechanisms in FreeRTOS. Task notifications are a lightweight, faster alternative when a single task needs to be signaled directly, making them ideal for one-to-one task communication. Unlike semaphores, they do not require a separate storage object and operate directly on the receiving task, reducing overhead. Binary semaphores allow multiple tasks to wait on the same event, with priority-based or first-come-first-served access, making them more flexible for complex synchronization needs.
Task notifications are preferable in scenarios with a fixed sender-receiver pair, while binary semaphores remain necessary when multiple tasks need to compete for a resource or when the waiting task is unknown in advance.
You can read the FreeRTOS documentation on task notifications and this forum thread for a comprehensive answer.
Thanks, It really helpful.
Sorry, for asking this question in this thread in advance
Would you share me some useful reference books or websites for tutorial, in which I can take guide for my projects.
You can check out the ā€˜FreeRTOS Reference Manual’ and ā€˜Mastering the FreeRTOS-Kernel’ for in-depth learning.
If you’re just starting out, explore the Beginner’s Guide to FreeRTOS.
For hands-on experience, the FreeRTOS Tutorials (Lab Project) are a great resource.
Hope this helps!
