Willhelm, the code in FreeRTOS_FD_ISSET() can be read as follows:
if xSocket is part of ( connected to ) xSocketSet, the select event mask in xSocketBits will be returned.
This mask has 4 bits, more or less comparable to the BSD select() :
eSELECT_READ /* the socket has data in its RX buffer */
eSELECT_WRITE /* the socket has space in its TX buffer */
eSELECT_EXCEPT /* the socket has had an exception (connection closed) */
eSELECT_INTR /* and API call got interrupted after FreeRTOS_SignalSocket() was called. */
eSELECT_READ has a second use: when a socket in listening mode receives a new connection, the event is generated.
Likewise, eSELECT_WRITE is generated as soon as connect() leads to a TCP connection.
So for listening “server” sockets, it is important to enable eSELECT_READ, and for a connecting “client” sockets, it is recommended to enable the eSELECT_WRITE event.
When FreeRTOS_send() returns less bytes than expected, or the error -pdFREERTOS_ERRNO_ENOSPC, it is good to enable eSELECT_WRITE for that socket, and get woken up as soon as there is space.
But eSELECT_WRITE can be nasty: when it occurs you either send data, or disable it. If not, it will come back again and again. Nothing peculiar here: the same behaviour can be expected on a PC.
Inheritance: when a server socket receives a new connection, the new connection will automatically belong the the same select group, and it will have the eSELECT_READ and eSELECT_EXCEPT bits set.
