"No Source Available" when debugging .axf file with gdb
I’m running the Demo for the LM3S811 on QEMU, but I can’t debug it properly because I get the message “No Source Available”.
qemu-system-arm -machine lm3s811evb -kernel ./gcc/RTOSDemo.axf -s -S
and on another terminal I’m running gdb with:
 gdb-multiarch ./gcc/RTOSDemo.axf
then I’m connecting to qemu with target remote :1234
What I’m I missing? Thanks in advance.
@sofia-am You’re using the demo at CORTEX_LM3S811_GCC demo right?
To get debug symbols, you’ll need to add one of the following flags to CFLAGS in the makedefs file:
-g
-ggdb
Depending on what level of debug info you want included. You can refer to the gcc documentation on the topic for more info.
