I am having an issue where after a while of running my program I have a large amount of these messages:
TCP: No active socket on port 65389 (a601a73ip:17000) ``TCP: No active socket on port 541 (a601a73ip:17000) ``TCP: No active socket on port 5009 (a601a73ip:17000) ``TCP: No active socket on port 52822 (a601a73ip:17000) ``TCP: No active socket on port 7435 (a601a73ip:17000) ``TCP: No active socket on port 2041 (a601a73ip:17000) ``TCP: No active socket on port 16000 (a601a73ip:17000) ``TCP: No active socket on port 2910 (a601a73ip:17000) ``TCP: No active socket on port 1521 (a601a73ip:17000) ``TCP: No active socket on port 8181 (a601a73ip:17000) ``TCP: No active socket on port 58080 (a601a73ip:17000) ``TCP: No active socket on port 44443 (a601a73ip:17000) ``TCP: No active socket on port 1088 (a601a73ip:17000)
Now the program is still running, but I would like to get to the bottom of why this is happening. I believe this may occur when I disconnect from a socket, but I am not connected to the network?
Any thoughts would be appreciated.
