I have managed to got the demo for avr work on my atmega128L with stk500 & stk501.
Now i try to add a task to the demo version for avr but the system seems to hang in my taskcreate routine.
Anybody who has the time to explain or has some code that i can add to the demo for example toggle a led connected to porta or something so i can learn how to create a very simple task to start with.
The Mega128 has more RAM than the 323 - for which the FreeRTOS download is configured. Try increasing the heap size. To do this look in the file FreeRTOS/Demo/AVR_ATMega323_WinAVR/FreeRTOSConfig.h (assuming you are using GCC). In this file you will see the definition configTOTAL_HEAP_SIZE - you can increase this to 2500 (or more). This will give more RAM to the kernel so it can create more tasks.
To see a simple task that simply flashes an LED at a fixed rate look at the file FreeRTOS/Demo/Common/Minimal/Flash.c. This creates three identical tasks that do just this.
