I downloaded the FreeRTOSv202112.00 of include and source files. I need to build the source files on VS code IDE and create the library. Then I need to run an application on QEMU environment using the library being created.
How can I cross-compile the freertos source files on VS code to generate library for target environment or QEMU?
