Mutex in ISR
roujesky wrote on Friday, May 29, 2015:
I know this had to have been discussed before, but searching the forum fails me…
PIC32 and FreeRTOS application. I have a hardware interrupt (INT0) which increments a long variable everytime it fires. I have a task that runs every 100ms which reads and clears that variable.
I thought I could use xSemaphoreTake and xSemaphoreGive in the ISR, but that crashes the program. Then I looked at xSemaphoreGiveFromISR, but that doesnt work either.
So how do expert FreeRTOS developers create exclusion between the task and ISR. I have the “Using the FreeRTOS Kernel… PIC32 edition”, but the example doesnt seem to fit.
thanks!
amsffrtos wrote on Friday, May 29, 2015:
The “FromISR” versions should certainly work, but check your FreeRTOSConfig.h to make sure that configMAX_SYSCALL_INTERRUPT_PRIORITY is set at least as high as the priority level of your interrupt handler.
tlafleur wrote on Friday, May 29, 2015:
You can also turn off interrupts for a very short time to read variable…
volatile long myVarable
long myNewVarable
task…
taskDISABLE_INTERRUPTS ();
myNewVarable = myVarable;
taskENABLE_INTERRUPTS ();
On Fri, May 29, 2015 at 2:48 PM, Robert H. Oujesky roujesky@users.sf.net
fails me…
I thought I could use xSemaphoreTake and xSemaphoreGive but that crashes
either.
thanks!
Mutex in ISR
https://sourceforge.net/p/freertos/discussion/382005/thread/9442dd83/?limit=25#a831
Sent from sourceforge.net because you indicated interest in
SourceForge.net: Log In to SourceForge.net
To unsubscribe from further messages, please visit
~~ _/) _/) _/) ``` _/) ~~
Tom Lafleur
heinbali01 wrote on Saturday, May 30, 2015:
I would vote for Tom’s solution:
uint32_t ulTickCount = 0ul;
void a_task( void *pvParameters
    for( ;; )
        /* Reading a 32-bit variable in 32-bit memory
        should be safe. */
        if( ulTickCount != 0ul )
            ulTickCount--;
void an_isr()
    /* The task has protected itself against possible
    interrupts.  We're not expecting a nested interrupt
    that also accesses 'ulTickCount'. */
    ulTickCount++;
Programmers dislike disabling interrupts, but in the above case I see no better solution. As you’ll know the compiler will create at least 3 instructions for a de- or increment in memory:
  ulTickCount--;
      ldr  r2, [r3]    // Load from memory
      sub  r0, r2, #1  // Decrease with 1
      str  r0, [r3]    // Store in memory
Getting an interrupt in-between these instructions would be fatal, ulTickCount gets corrupted.
About xSemaphoreGive :
When you are sharing resources/objects among tasks, a semaphore or a mutex can be very useful. Before using the resource you take the semaphore, when ready you give the semaphore:
    if( xSemaphoreTake( xUSARTAccessSemaphore, ( TickType_t ) 10 ) )
        vUSARTWrite( pcMessage, xLength );
        xSemaphoreGive( xUSARTAccessSemaphore );
About xSemaphoreGiveFromISR:
Sometime a resource becomes available when an interrupt fires, for instance when data is received or sent.
Suppose a USART receives characters and an ISR stores them into buffers. xSemaphoreGiveFromISR is called as soon as one buffer is full:
void an_isr()
BaseType_t xHigherPriorityTaskWoken = psFALSE;
    /* Read a character from the register: */
    ucUSARTBUffer[ xUSARTIndex ][ xUSARTHead ] = UDR0;
    if( ++xUSARTHead == USART_BUF_LENGTH )
        xUSARTHead = 0;
        if( ++xUSARTIndex == USART_BUF_COUNT )
            xUSARTIndex = 0;
        /* As noticed above: the priority of this ISR should not
        be higher than configMAX_SYSCALL_INTERRUPT_PRIORITY. */
        xSemaphoreGiveFromISR( xUSARTSemaphore, &xHigherPriorityTaskWoken );
Regards,
Hein
richard_damon wrote on Saturday, May 30, 2015:
My first modification would be to use taskENTER_CRITICAL/taskEXIT_CRITICAL if the interrupt has a priority below configMAX_SYSCALL_INTERRUPT_PRIORITY (as would be required to call any FreeRTOSAPI). This typically only disables those interrupts and not higher priority interrupts, it also nests properly incase your code that needs protection might be in a function called within a bigger critical section.
