this is what actually i asked i knew it was not possible but still if it’s possible with this controller i don’t know since i raised this.
Ok. if switching between three tasks will it give an efficient result.??
and how .??
and how .??
What do you mean by “efficient” result? From FreeRTOS perspective, if you run 3 tasks at the same priority, each of them will run in a round robin fashion.
Actually, task3 -operating relays is like sensor operations so if relays operating means at this point I need both ADCs values, this is my situation.
if it works with the round robin concept means task3 running means task1 and task2 are in a ready state right.??
so while running task3 at this point I couldn’t get proper ADC values correct.??
After talking, we determined that the problem @_sagar is trying to solve is - “Whenever any application task wants to consume ADC values, they must be up-to-date.”
This can be ensured by running ADC reader tasks at a higher priority than other tasks. ADC reader tasks block waiting for a task notification from their respective ISRs, thereby allowing other lower priority tasks to run. The following diagram explains the solution -
