bernardoreis wrote on Wednesday, June 22, 2011:
Hello. I’d like to know witch families of MSP430 are supported by freeRTOS.
I have a MSP430F2274 model.
rtel wrote on Thursday, June 23, 2011:
There are projects provided for MSP430F449 (MSP430 core) and MSP430F5438 (MSP430X core, small/medium/large models). As both the MSP430 and MSP430X cores are supported you should be able to create a project for any device that has enough RAM.
harikk09 wrote on Tuesday, June 28, 2011:
I think freeRTOS 7 can support upto the 5xx series of msp430.
I am using msp430f5418 with freeRTOS 7.
the 7th version can also support the large and medium data models.
since you are using 2xx, you might not need these data models.
FreeRTOS 6 had support for 4xx devices but it lacks support for large and medium data models
So may be you can use either FreeRTOS 6 or 7 with some modifications for your specific device…
Regards,
hari
Regards,
hari
mobius46 wrote on Thursday, July 14, 2011:
Very new to Free RTOS and using the MSP430F5438
Installed CCS4 and FreeRTOS Demo to C:\FreeRTOS\Demo\MSP430X_MSP430F5438_CC4
per the instructions. Problem is it does not make “out of the box”
When I attempt to build it failed when linking see the final message below:
“…/lnk_msp430f5438a.cmd”
<Linking>
error: output file “RTOSDemo.out” exceeds code size limit
error: errors encountered during linking; “RTOSDemo.out” not built
>> Compilation failure
gmake: *** Error 1
gmake: Target `all’ not remade because of errors.
Build complete for project RTOSDemo
Thanks for any help you can provide….gordon
edwards3 wrote on Thursday, July 14, 2011:
<Linking>
You are using an evaluation version of the compiler that will not build a project that is more than a few K in size. It is a tool error, not an rtos error.
gmake: *** Error 1
So you are using an evaluation of the compiler with a make file instead of the IDE. I’m guessing you didnt buy it.
