rtel wrote on Wednesday, May 25, 2011:
> Hi, I’m currently evaluating the timing within FreeRTOS using an
> oszilloscope and the IO-pins of my AT91SAM7X (running at 48 MHz).
> Assuming there are several tasks, each waiting to receive from it’s
> queue. The Object passed thorugh the queues is a struct with three
> int-entries. Within an ISR calling xQueueSendToBackFromISR() followed
> by portYIELD_FROM_ISR() takes about nn s. Another nn s later the task
> waiting for that queue is running and processing the data. But when
> using xQueueSendToBack() from a normal task just this call already
> takes nn s. Until the blocked task is running there are even another
> nn s.
> So the time needed to pass information and context from one place to
> another ammounts to nn s when the source is an ISR and nn s when two
> normal tasks are involved. I’m not complaining (other RTOS here in
> the office need a multiple of CLK to achieve such times) but am
> curious about the why.
Looking at the source code will give you the answer. Basically, sending from an ISR is much leaner code because it has less functionality. It has less functionality because you cannot block on a queue from an ISR. Less code + less functionality = faster execution. Also, you want code executed in an ISR to always be fast.
Using a queue from a task means the queue has to do much, much, more.
One of the things an RTOS should always do is queue tasks that are blocked on the same queue in their priority order. That requires code and execution time. That code and execution overhead is not required when the queue is used from an interrupt.
Also, consider the case of a task being blocked on a queue to wait for data to arrive (it wants to read from a queue, but the queue is empty, so opts to block to wait for the queue not to be empty). If something posts data to the queue, then the task will be unblocked, if it is the highest priority task that was waiting for the data. However, it is possible that, before the unblocked task actually executes (other tasks and interrupt might execute first), the data that was posted to the queue is removed by something else. When that happens, when the unblocked task actually does execute, it will find the queue empty again. It would be wrong for it to return from the queue read function without data if its block time had not expired. Therefore, what it does, is re-calculate its block period to take into account the time it had already spent in the blocked state previously, then re-enter the blocked state to wait for another item to be sent to the queue or the remainder of its block period to expire. All this takes code and time, but code and time that is not required when the queue is used from an interrupt.
If other RTOSes don’t exhibit this same behaviour, then their end behaviour will be incorrect. So, FreeRTOS could make its queues faster, by effectively introducing subtle bugs. .
Probably more detail than was required, but demonstrates the point I think (if you can follow my long winded explanation).
> Driven, of course, by the question: “Why not
> using the FromISR()-Call also within my normal task when gaining so
> much speed with that?”
It is completely legitimate to use “FromISR” queue and semaphore calls from tasks, if the application does not require the additional functionality that is described above. The FromISR versions will not allow the task to block if a sending task finds the queue full, or a receiving task finds the queue empty, for example.
There are actually three ways of sending and receiving from a queue. You have identified two already. The third speeds up the sending and receiving from a task by introducing longer critical sections. I am deprecating that method however, so it is not recommended for new designs. It just shows another example of a compromise, longer critical sections for faster execution speed.
> The pre-emptive functions aren’t of much importance for my project
> since everything happens within a fraction of a tick. So are there
> any downsides about using the faster ISR-functions everywhere?
Choose the best function for your application. There is not one answer that is correct for every occasion. Just be aware of the differences between the functions, and select the best fit.
