When trying to build the lwip http server under arm STM32F407G DISC1 evaluation hardware on ubuntu using the STM32CubeIDE 1.3.1 I get a file not found for “fsdata_custom.c”. In the configuration for middleware HTTPD I see at the bottom of the list "HTTPD_USE_CUSTOM_FSDATA (…) is Enabled. I can not disable it. I also believe if I could I would just get a file not found for “fsdata.c”.
I have tried making the fsdata.c from the old perl script makefsdata, and move the fsdata.c generated to fsdata_custom.c but the c file generated does not compile and complains about NULL not defined and array type as incomplete element type.
So now what?
