are defined in the freertos component’s task.h. But these aren’t included in the AmazonFreeRTOS build. So I was wondering how I could use this component for my ESP32?
Thank you bringing this issue into our attention. I have a few questions/comments related to the issue that you are facing.
Which version of amazon-freertos are you using?
Are you following the build steps from AWS docs for building for FreeRTOS for ESP?
ESP-IDF is maintained by ESP. Also the file gdbstub.c is maintained by ESP. I have also noticed that the FreeRTOS kernel version used in the ESP-IDF release 3.3 is an older version(V8.2.0) whereas the latest kernel version is V10.3.1. ESP forums would be a good resource for checking if there are any list of supported FreeRTOS kernel versions to be used with ESP-IDF release 3.3.
Thanks for the answers 1 and 2.
For the kernel version, kernel version V8.2.0 task.h file doesn’t have TaskSnapshot_t and uxTaskGetSnapshotAll(). Whereas the task.h included in the ESP-IDF V3.3 has those members. This difference could be a ESP specific modification. So Espressif forum (link ) could be the best place to answer this, so could you try posting your query there?
Okay but I am simply using the ESP version that is included in the AmazonFreeRTOS git repo. Am I expect to upgrade that version? I suspect that would break somethings.
