i’m using a pic32mz1024efg064 with mikroc pro for pic32 compiler. this compiler uses freeRTOS version 9… i’m new to this and have a project that doesn’t really do much at this point but is getting rather large with nested concurrent running state machines that are stacked on top of each other… i would like to simplify the code into threads so i could write blocking fuctions. that being said what are the absolute minimum required files that i need to include to run freeRTOS with the most basic functionallity of a time slice scheduler? ideally i’d like to have about a dozen threads running concurrently with out any inner task communication, mutexes or timers… also is there a way that i can run freertos with case sensitivity disabled so i don’t have to change everything i’ve written over the last year? thanks
Sorry - I don’t understand that question. FreeRTOS is just C code it
doesn’t know anything about case sensitivity.
