Microblaze AXI SPI interrupt issue with FreeRtos
Hello!
I try to implement an SPI-interface with FreeRtos on a Microblaze system (with Wiznet W6100). The interrupt handler gets triggered only once and then the code stops at “while (Spi_Wiznet_TransferInProgress);”
I have used almost the same code without rtos and it is working. That means the hardware is ok. I have used for the non-FreeRtos application the AXI-SPI with FIFO. For the FreeRtos application i deactivated the FIFO after some tries as I have changed the interrupt-configuration to the port-functions from FreeRtos and activated the XSP_INTR_RX_FULL_MASK - interrupt.
The SPI interface runs with 25 MHz and the Microblaze with 100 MHz.
I post only the (in my opinion) relevant part of my code. If needed, I can upload the whole main.c.
I use the following code for configuration of the SPI-interface:
	XSpi_Config *ConfigPtr_Spi_Wiznet;
	ConfigPtr_Spi_Wiznet=XSpi_LookupConfig(DeviceID_SPI_Wiznet);
    XSpi_CfgInitialize(&Spi_Wiznet, ConfigPtr_Spi_Wiznet, ConfigPtr_Spi_Wiznet->BaseAddress);
    //	SetupInterruptSystem(); //not used, for FreeRtos I have to use the ported functions
    //	XSpi_SetStatusHandler(&Spi_Wiznet, &Spi_Wiznet, (XSpi_StatusHandler) Spi_Wiznet_Handler);   //not used, for FreeRtos I have to use the ported functions
    XSpi_SetOptions(&Spi_Wiznet, XSP_MASTER_OPTION  );// | XSP_MANUAL_SSELECT_OPTION );
	XSpi_SetSlaveSelect(&Spi_Wiznet, cs_wiznet);
    XSpi_Start(&Spi_Wiznet);
code for interrupt configuration - at the beginning of a task (not in the while loop)
static void tf_init_wiznet(void* parameters){
    const TickType_t x10second = pdMS_TO_TICKS( DELAY_10_SECONDS );
	xil_printf( "Enable Interrupts\r\n" );
	int xStatus;
	xStatus=xPortInstallInterruptHandler(XPAR_CONTROLLER_MICROBLAZE_0_AXI_INTC_WIZNET_AXI_SPI_WIZNET_IP2INTC_IRPT_INTR, (XInterruptHandler) Spi_Wiznet_Handler, &Spi_Wiznet);
	vPortEnableInterrupt(XPAR_CONTROLLER_MICROBLAZE_0_AXI_INTC_WIZNET_AXI_SPI_WIZNET_IP2INTC_IRPT_INTR);
	XSpi_IntrEnable(&Spi_Wiznet,XSP_INTR_RX_FULL_MASK);           //use without FIFO!!
	XSpi_IntrGlobalEnable(&Spi_Wiznet);
	xil_printf( "Interrupt enabled\r\n" );
    xil_printf( "Start Init W6100\r\n" );
functions for SPI transmit/receive
uint8_t my_wizchip_read(void){
	uint8_t rx_data[1]={0};
	uint8_t tx_data[1]={0xFF};
	Spi_Wiznet_TransferInProgress=TRUE;
	XSpi_Transfer(&Spi_Wiznet, tx_data, rx_data, 1);
	return rx_data[0];
void my_wizchip_write(uint8_t wb){
	uint8_t tx_data[1]={wb};
	return;
function for SPI Interrupt handler
void Spi_Wiznet_Handler(void *CallBackRef)
	xil_printf( "SPI Int started\r\n" );
	portENTER_CRITICAL();       //tried with and without portEnter- and portEXIT_CRITICAL
	Spi_Wiznet_TransferInProgress=FALSE;
	/*      //code that i have used in the non-RTOS application with (void *CallBackRef, u32 StatusEvent, u32 ByteCount)
	if (StatusEvent == 0x4)		//XST_SPI_TRANSFER_DONE)
		Spi_Wiznet_ErrorCount++;
	XSpi_IntrClear(&Spi_Wiznet,XSP_INTR_RX_FULL_MASK);
	xil_printf( "SPI Int endedr\n");
	portEXIT_CRITICAL();        //tried with and without portEnter- and portEXIT_CRITICAL
My questions:
Has anybody an idea why my interrupt doesn’t get triggered a second time?
Has anybody a working example with AXI-SPI interrupt and FreeRtos?
I made some tests with GPIO-interrupts…they worked well.
best regards
Dabrzn
You can take a look at how to install the handlers on the page that describes how to use FreeRTOS on Cortex-A processors?Also, the Zynq demo in the FreeRTOS download and the FreeRTOS+TCP examples can be used as a reference.
This link provides a reference on AXI interrupt on FreeRTOS using a Xilinx board.
Please see if these links are helpful.
