The Idle Task Provides good way to sleep the PIC32MX Controller but I cant see a way to scale the Clock at run time Just Like WIndows 10 Scales down the processor Clock instead of going to Hibernate to conserve Power
There is no clock scaling built in, but there are hooks and examples
that allow you to stop the tick and therefore turn off the CPU core,
which will save even more power than just slowing it down. Google for
“FreeRTOS Tickless Idle”, although I don’t think there are examples for
the PIC32.
If tickless idle doesn’t do enough for you, (you need ticks but not doing much), this is likely off of some program state machine that can decide that you aren’t going to need to do much for awhile and can drop the clock rate. One big trick, which I don’t know the PIC32MX well enough to know how easy it is, is that many periphearals (UARTS, Timers, etc) don’t like the clock changing on them, but Microchip likely has examples of how to do this. If it doesn’t significantly impact the tick interrupt, then FreeRTOS doesn’t need to know about it.
stop the tick and therefore turn off the CPU core, which will save even more power than just slowing it down.
USB Catch
PIC32MX-Reference Manual:—>
27.7 OPERATION IN DEBUG AND POWER-SAVING MODES
27.7.1 Operation in Sleep
Use of Sleep mode is only recommended in two cases:
• USB OTG module is disabled
• USB OTG module is in a Suspend state.
—> USB is also used as Charger for Battery. =>CPU Can’t Run at Full Speed Either.
LEDs Catch
LEDs need to Blink with CPU consuming Low Values of Current(1mA@500KHz=FRC/16) contrast to {75mA@100MHz, 80uA@Sleep}
How can these both be achieved when PIC32MX Enters Sleep Mode …
Also wake up time of PIC32MX470F512H is around
SY00-- TPU-- Power-up Period Internal Voltage Regulator Enabled–600us
Google for “FreeRTOS Tickless Idle”
Below is the code Produced by MPLAB-X v4.20 with Harmony Configurator v2.06 with FreeRTOS v10.0.1 in task.c file(Code Given at End)
But:
portSUPPRESS_TICKS_AND_SLEEP( xExpectedIdleTime );
is not implemented for PIC32MX470F512L (in FreeRTOS.h) . Is this Correct?
I am Looking for "Official FreeRTOS versions attempt to remove any slippage (as far as is possible) by providing a more intricate implementation. "
/* This conditional compilation should use inequality to 0, not equality
to 1. This is to ensure portSUPPRESS_TICKS_AND_SLEEP() is called when
user defined low power mode implementations require
configUSE_TICKLESS_IDLE to be set to a value other than 1. */
#if ( configUSE_TICKLESS_IDLE != 0 )
TickType_t xExpectedIdleTime;
/* It is not desirable to suspend then resume the scheduler on
each iteration of the idle task. Therefore, a preliminary
test of the expected idle time is performed without the
scheduler suspended. The result here is not necessarily
valid. */
xExpectedIdleTime = prvGetExpectedIdleTime();
if( xExpectedIdleTime >= configEXPECTED_IDLE_TIME_BEFORE_SLEEP )
vTaskSuspendAll();
/* Now the scheduler is suspended, the expected idle
time can be sampled again, and this time its value can
be used. */
configASSERT( xNextTaskUnblockTime >= xTickCount );
/* Define the following macro to set xExpectedIdleTime to 0
if the application does not want
portSUPPRESS_TICKS_AND_SLEEP() to be called. */
configPRE_SUPPRESS_TICKS_AND_SLEEP_PROCESSING( xExpectedIdleTime );
traceLOW_POWER_IDLE_BEGIN();
traceLOW_POWER_IDLE_END();
mtCOVERAGE_TEST_MARKER();
( void ) xTaskResumeAll();
#endif /* configUSE_TICKLESS_IDLE */
That is right, the macro is still called though so you can still provide
an implementation for the PIC32. The Cortex-M ports have a ‘default’
implementation of the necessary only - to get ultra low power modes
operational it is necessary to write a port specific implementation (to
use a chip specific low power clock) on those parts too.
