system
(system)
February 10, 2013, 6:17pm
1
fojtik wrote on Sunday, February 10, 2013 :
This memory manager can reuse standard C-lib functions. Sometimes the malloc, realloc and free could be optimized more precise in C lib than those proposed in RTOS…
FreeRTOS\Source\portable\MemMang\HeapClib.c:
#include <stdlib.h>
#include "FreeRTOS.h"
#include "task.h"
void vPortFree( void *pv )
if(pv)
vTaskSuspendAll();
free(pv);
xTaskResumeAll();
void *pvPortMalloc(size_t xWantedSize)
void *Mem;
vTaskSuspendAll();
Mem = malloc(xWantedSize);
xTaskResumeAll();
return (Mem);
rtel
(Richard Barry)
February 11, 2013, 12:06pm
2
rtel wrote on Monday, February 11, 2013 :
What is the difference between this and heap_3.c?
Heap_4.c is currently the preferred scheme if RAM is going to be freed as well as allocated.
system
(system)
February 11, 2013, 12:44pm
3
fojtik wrote on Monday, February 11, 2013 :
Sorry, I overlook that. Anyway, this memory scheme performs a little better in Keil. You can use safelly malloc and free inside your code and everything is synchronized. Keil can use in its C-lib externally provided mutex.
free(pv);
return malloc(xWantedSize);
/*--------------------------- _mutex_initialize -----------------------------*/
int _mutex_initialize (_SYNC_t *mutex)
/* Allocate and initialize a system mutex. */
vSemaphoreCreateBinary(*mutex); /*Create semaphore*/
return (1);
/*--------------------------- _mutex_acquire --------------------------------*/
__attribute__((used)) void _mutex_acquire(_SYNC_t *mutex)
/* Acquire a system mutex, lock stdlib resources. */
if(RTOS_STATE == RTOS_RUNNING)
{ /* RTX running, acquire a mutex. */
xSemaphoreTake(*mutex, 500);
/*--------------------------- _mutex_release --------------------------------*/
__attribute__((used)) void _mutex_release (_SYNC_t *mutex)
/* Release a system mutex, unlock stdlib resources. */
{ /* RTX runnning, release a mutex. */
xSemaphoreGive(*mutex);
//http://www.keil.com/forum/16315/
