In version 6.1 of freertos there is demo for the freescale mcf52221demo board. However I guess it has been developped for a old version of codewarrior since it doesn’t compile on either CodeWarrior 10 (after conversion) or on Codewarrior 7.3. Is there an update for CodeWarrior 10 available somewhere?
Thanks in advance
Apparently the compiler complain about __declspec(interrupt:0) . I am very new to mcu development and don’t know how to handle this. Here is the output of the compiler:
**** Build of configuration INTERNAL_FLASH for project RTOSDemo ****
‘Regenerating dependency file: Sources/FreeRTOS_Tick_Setup.d’
‘Building file: …/Sources/FreeRTOS_Tick_Setup.c’
‘Invoking: ColdFire Compiler’
“C:\Program Files\Freescale\CW MCU v10.0\eclipse\…/MCU/ColdFire_Tools/Command_Line_Tools/mwccmcf” @“Sources/FreeRTOS_Tick_Setup.args” -o “Sources/FreeRTOS_Tick_Setup.obj” “…/Sources/FreeRTOS_Tick_Setup.c”
…/MCU/ColdFire_Tools/Command_Line_Tools/mwccmcf|Compiler|Error
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|57|11|9|3194|9)
=__declspec(interrupt:0) void vPIT0InterruptHandler( void );
>identifier expected
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|121|11|9|6260|9)
>identifier expected
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|122|0|1|6309|1)
>declaration syntax error
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|126|12|1|6391|13)
= (*(vuint16*)(0x40150000)) |= MCF_PIT_PCSR_PIF;
>’)’ expected
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|129|1|20|6463|20)
= ulSavedInterruptMask = portSET_INTERRUPT_MASK_FROM_ISR();
>undefined identifier ‘ulSavedInterruptMask’
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|130|22|1|6544|1)
= vTaskIncrementTick();
>identifier ‘vTaskIncrementTick()’ redeclared as ‘__regabi int (…)’
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS.org\headers\task.h|1162|51|1|40888|1)
=void vTaskIncrementTick( void ) PRIVILEGED_FUNCTION;
>identifier ‘vTaskIncrementTick()’ was originally declared as ‘__regabi void
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|131|58|1|6605|1)
= portCLEAR_INTERRUPT_MASK_FROM_ISR( ulSavedInterruptMask );
>identifier ‘ulPortSetIPL(unsigned long)’ redeclared as ‘__regabi int (int)’
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS.org\headers\portmacro.h|94|51|1|4346|1)
=unsigned portLONG ulPortSetIPL( unsigned portLONG );
>identifier ‘ulPortSetIPL(unsigned long)’ was originally declared as ‘__regabi
>unsigned long (unsigned long)’
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|136|1|1|6784|1)
(C:\Documents and Settings\Herve\FreeRTOSV6.1.0\FreeRTOSV6.1.0\Demo\ColdFire_MCF52221_CodeWarrior\RTOSDemo\Sources\FreeRTOS_Tick_Setup.c|140|0|1|6816|1)
