heinbali01 wrote on Thursday, June 07, 2018:
The items that you mention are part of an old demo module Test_Code\Sockets_Test.c
. I’m sorry but it has not been updated for a long time.
If I am not mistaken, xZeroCopyBufferDescriptor_t
should be:
typedef NetworkBufferDescriptor_t *xZeroCopyBufferDescriptor_t;
Note that nowadays, the initial ‘x’ would not be used for a typedef anymore, so it would become ZeroCopyBufferDescriptor_t
ipconfigMAX_UDP_DATA_LENGTH
indicates the length of the UDP packets that are transmitted.
The function FreeRTOS_GetZeroCopyBuffer()
was a wrapper, it would call the function pxGetNetworkBufferWithDescriptor()
I think it looked lke this:
BaseType_t FreeRTOS_GetZeroCopyBuffer( xZeroCopyBufferDescriptor_t *pBuffer, size_t xRequestedSizeBytes, TickType_t xBlockTimeTicks )
BaseType_t xResult;
*pBuffer = pxGetNetworkBufferWithDescriptor( xRequestedSizeBytes, xBlockTimeTicks );
if( *pBuffer != NULL )
xResult = pdPASS;
xResult = pdFAIL;
return xResult;
Zero-copy for UDP:
For UDP sockets, zero-copy means that the user doesn’t pass character buffers, but Network Buffers, which travel from the Network Interface all the way to the application ( FreeRTOS_recvfrom()
), without ever getting ( mem- ) copied.
The same for FreeRTOS_sendto()
: the user fills and sends a Network Bufferm which won’t get copied neither. If you have a zero-copy driver, the memory of the Network Buffer will be passed directly to DMA.
The actual library sources files of FreeRTOS+TCP are these nine:
FreeRTOS_ARP.c
FreeRTOS_DHCP.c
FreeRTOS_DNS.c
FreeRTOS_IP.c
FreeRTOS_Sockets.c
FreeRTOS_Stream_Buffer.c
FreeRTOS_TCP_IP.c
FreeRTOS_TCP_WIN.c
FreeRTOS_UDP_IP.c
I hope that they compile without too many problems. Yes we also tested it with the GCC Arm toolchain.
Max, are you sure you need the /multi version of FreeRTOS+TCP? For which platform, if I may ask?
The /multi version has support for multiple Network Interfaces, and also multiple IP-addresses. it also implements IPv6, but that part is still under construction.
