Making Led blink and stop on arduino uno
ose wrote on Saturday, April 14, 2018:
Hi, I am new to freertos and i have been trying out some stuffs . I have been able to make the led blink on my ardunio uno board but I am trying to make it blink for sometime andthen stop but i dont know how to implement that on freertos.
I know i need a for loop to indicate how mnay times it should blink but how to implement that on freertos is where i am stucked at.
Can someone please advice me on how to go about that?
Thank you.
Hers is an exmaple of the code making the led blink normally witout stopping
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "semphr.h"
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
static void TaskBlinkyellowLED(void* pvParameters);
int main()
  xTaskCreate(TaskBlinkyellowLED, (const portCHAR*) "yellowLED", 256, NULL, 3, NULL);
  vTaskStartScheduler();
  for (;;)
  return 0;
// Main yellow LED Flash
  // set pin 5 of PORTB for output
  DDRB |= _BV(DDB5);
  TickType_t xLastWakeTime = xTaskGetTickCount();
  while (true)
		  // LED on
    PORTB |= _BV(PORTB5);
    vTaskDelayUntil(&xLastWakeTime, (1000/ portTICK_PERIOD_MS));
    // LED off
    PORTB &= ~_BV(PORTB5);
    vTaskDelayUntil(&xLastWakeTime, (1000 / portTICK_PERIOD_MS));
  vTaskDelete(NULL);
void vApplicationStackOverflowHook(TaskHandle_t xTask, portCHAR* pcTaskName)
  // main LED on
  DDRB |= _BV(DDB5);
  // die
  while (true)
    _delay_ms(250);
    _delay_ms(250);
rtel wrote on Saturday, April 14, 2018:
Perhaps more of a C question than a FreeRTOS question…can you just replace the while() looop with a for loop?
int x;
  DDRB |= _BV(DDB5);
  for( x = 0; x < 10; x++ )
          // LED on
    // LED off
  vTaskDelete(NULL);
Or if you want to have fun - use an autoreloading software timer that has a callback function that:
  1. Toggles the LED.
  2. Counts the number of times it has executed, and when it has executed the required number of times, stops itself.
:o)
ose wrote on Sunday, April 15, 2018:
Thank You very much
