Hi all, I have encountered a need that I’m not sure how to handle. Essentially, I have a set of non-adjacent memory regions that I would like to use and so it kind of made sense to me to attempt to make newlib use heap_5.c. To note, I have started with Dave Nadler’s heap_useNewLib solution and has been used successfully so far. I would like to keep only one memory management system as it is now, and not a separate memory management system for FreeRTOS and one for newlib.
I started going down the path of replacing the _sbrk_r implementation to simply forward calls to heap_5’s pvPortMalloc implementation. Then also wrapped the free function to simply forward the call to heap_5’s vPortFree. I verified my application does not use realloc, which is something that FreeRTOS doesn’t have equivalent port version as already pointed out by Dave in his article. I kept the __malloc_lock and __malloc_unlock functions intact but not sure it’s actually needed since heap_5’s pvPortMalloc implementation already calls vTaskSuspendAll/vTaskSuspendResume.
Initial testing shows that it works properly for allocating memory (calling new and malloc) and it uses the non-contiguous memory regions appropriately. However, I seem to have an issue when calling delete or free. a configASSERT gets hit because pxLink->pxNextFreeBlock != NULL. I haven’t figured out why this is happening.
Overall, am I going about this the right way, which bubbles up to attempting to make newlib use FreeRTOS memory management? Has anyone already solved this and/or have any suggestions to recommend? Thanks in advance.
