nobody wrote on Tuesday, July 25, 2006:
Hi
I’m back …
>Most of the ports #define away the inline at the bottom of portmacro.h. This gets around the problem
Great idee! First I didn’t understand exactly what you mean but now I do
The secound problem is in the common test files (demo/common/…)
We call the xTaskCreate fkt. and the secound parameter is implicitly casted to ( signed portCHAR * )
the problem is that my compiler now says:
“far pointer (implicitly) casted by near pointer”
because he differ const pointer(far 20bit FLASH) and normal pointer (near 16bit RAM)
I think I won’t be wrong we changed the implicit cast ( signed portCHAR * ) to (const signed portCHAR * ) beacause the xTaskCreate fkt. body is
signed portBASE_TYPE
xTaskCreate( pdTASK_CODE pvTaskCode,
!!   const signed portCHAR * const pcName,       unsigned portSHORT usStackDepth, void *pvParameters, unsigned portBASE_TYPE uxPriority, xTaskHandle *pxCreatedTask )
and here is the build output I used TM
******** Cleaning…
******** Complete…
******** Executing…
AS30  -LM -finfo -O. ncrt0.a30
R8C/Tiny,M16C/60 Series Assembler system Version 5.10 Release1
COPYRIGHT(C) 1995(2004) RENESAS TECHNOLOGY CORPORATION
AND RENESAS SOLUTIONS CORPORATION ALL RIGHTS RESERVED
macro processing now
–assembler processing now
TOTAL ERROR(S)    00000
TOTAL WARNING(S)  00000
TOTAL LINE(S)     00280   LINES
DATA     0000000(00000H)  data_SE
DATA     0000000(00000H)  bss_SE
DATA     0000000(00000H)  data_SO
DATA     0000000(00000H)  bss_SO
DATA     0000000(00000H)  data_NE
DATA     0000000(00000H)  bss_NE
DATA     0000000(00000H)  data_NO
DATA     0000000(00000H)  bss_NO
DATA     0000512(00200H)  stack
DATA     0004096(01000H)  heap
ROMDATA  0000000(00000H)  rom_NE
ROMDATA  0000000(00000H)  rom_NO
DATA     0000000(00000H)  data_FE
DATA     0000000(00000H)  bss_FE
DATA     0000000(00000H)  data_FO
DATA     0000000(00000H)  bss_FO
ROMDATA  0000000(00000H)  rom_FE
ROMDATA  0000000(00000H)  rom_FO
ROMDATA  0000000(00000H)  data_SEI
ROMDATA  0000000(00000H)  data_SOI
ROMDATA  0000000(00000H)  data_NEI
ROMDATA  0000000(00000H)  data_NOI
ROMDATA  0000000(00000H)  data_FEI
ROMDATA  0000000(00000H)  data_FOI
CODE     0000000(00000H)  program
CODE     0000000(00000H)  program_S
CODE     0000000(00000H)  interrupt
CODE     0000192(000C0H)  vector
CODE     0000036(00024H)  fvector
CODE     0000288(00120H)  interrupt
( ncrt0.a30 )
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\…\Source\list.c
M16C/60 NC30 COMPILER V.5.30 Release 1
COPYRIGHT(C) 2001(2003,2004) RENESAS TECHNOLOGY CORPORATION
…\…\Source\list.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\…\Source\queue.c
…\…\Source\queue.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\…\Source\tasks.c
[Warning(ccom):…/…/Source/tasks.c,line 968] far pointer (implicitly) casted by near pointer
   ===>         xReturn = xTaskCreate( prvIdleTask, ( signed portCHAR * ) "IDLE", tskIDLE_STACK_SIZE, ( void * ) NULL, tskIDLE_PRIORITY, (;…
…\…\Source\tasks.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A main.c
main.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\…\Source\portable\NC30\M16c62A\port.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\Common\Minimal\integer.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\…\Source\portable\MemMang\heap_3.c
[Warning(ccom):…/…/Source/portable/MemMang/heap_3.c,line 58] assign far pointer to near pointer,bank value ignored
   ===>                 pvReturn = malloc( xWantedSize );
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\Common\Minimal\PollQ.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\Common\Minimal\flash.c
[Warning(ccom):…/Common/Minimal/flash.c,line 117] meaningless statements deleted in optimize phase
   ===>         xFlashRate /= portTICK_RATE_MS;
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A ParTest\ParTest.c
ParTest\ParTest.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A serial\serial.c
serial\serial.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\Common\Minimal\comtest.c
NC30  -c -I…/…/Source/include -I…/Common/include -I. -dir . -finfo -DNC30_M16C62A …\Common\Minimal\semtest.c
[Warning(ccom):…/Common/Minimal/semtest.c,line 119] far pointer (implicitly) casted by near pointer
   ===>                         xTaskCreate( prvSemaphoreTest, ( signed portCHAR * ) "PolSEM1", semtstSTACK_SIZE, ( void * ) pxFirstSemaphoreParameters,;…
[Warning(ccom):…/Common/Minimal/semtest.c,line 120] far pointer (implicitly) casted by near pointer
   ===>                         xTaskCreate( prvSemaphoreTest, ( signed portCHAR * ) "PolSEM2", semtstSTACK_SIZE, ( void * ) pxFirstSemaphoreParameters,;…
[Warning(ccom):…/Common/Minimal/semtest.c,line 137] far pointer (implicitly) casted by near pointer
   ===>                         xTaskCreate( prvSemaphoreTest, ( signed portCHAR * ) "BlkSEM1", semtstSTACK_SIZE, ( void * ) pxSecondSemaphoreParameters;…
[Warning(ccom):…/Common/Minimal/semtest.c,line 138] far pointer (implicitly) casted by near pointer
   ===>                         xTaskCreate( prvSemaphoreTest, ( signed portCHAR * ) "BlkSEM2", semtstSTACK_SIZE, ( void * ) pxSecondSemaphoreParameters;…
LN30 @.\freertos.cmd
Linkage Editor (ln30) for R8C/Tiny,M16C Series Version 5.10.01
now processing pass 1
processing ".\ncrt0.r30"
processing ".\list.r30"
processing ".\queue.r30"
processing ".\tasks.r30"
processing ".\main.r30"
processing ".\port.r30"
processing ".\integer.r30"
processing ".\heap_3.r30"
processing ".\PollQ.r30"
processing ".\flash.r30"
processing ".\ParTest.r30"
processing ".\serial.r30"
processing ".\comtest.r30"
processing ".\semtest.r30"
processing "Libraries"
now processing pass 2
processing "C:\MTOOL\LIB30\nc30lib.lib ( _I4DIV.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( _I4MODU.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( _I4MULU.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( BCOPY.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( BZERO.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( MALLOC.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( MEMCPY.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( MEMSET.r30 )"
processing "C:\MTOOL\LIB30\nc30lib.lib ( STRNCPY.r30 )"
DATA     0004781(012ADH) Byte(s)
ROMDATA  0000147(00093H) Byte(s)
CODE     0008743(02227H) Byte(s)
******** Finish…
