Hello!
I’m working with FreeRTOS 202210.01, my task is to transfer files to an FTP server. I use the FTP library provided by the developer and I manage to connect and transfer files. The problem is that at a random moment the transmission stops and in wireshark I see an error related to an attempt to retransmit the packet.
Also sometimes I get stuck in the recv() (lwip_recv_tcp) function from lwip_recvfrom (sockets.c). It seems to me that I haven’t fully configured lwipopts.h. My version is LWiP 2.1.2. I will be glad for any help, and I am attaching the lwipopts.h file:
#ifndef LWIP_HDR_LWIPOPTS_H
#define LWIP_HDR_LWIPOPTS_H
#include <platform_stdlib.h>
#include "platform_opts.h"
#define CONFIG_VIDEO_APPLICATION 1
* SYS_LIGHTWEIGHT_PROT==1: if you want inter-task protection for certain
* critical regions during buffer allocation, deallocation and memory
* allocation and deallocation.
#define SYS_LIGHTWEIGHT_PROT 1
/* Define LWIP_COMPAT_MUTEX if the port has no mutexes and binary semaphores
should be used instead */
#define LWIP_COMPAT_MUTEX 1
#define ETHARP_TRUST_IP_MAC 0
#define IP_REASSEMBLY 1
#define IP_FRAG 1
#define ARP_QUEUEING 0
#ifndef CONFIG_LWIP_DHCP_COARSE_TIMER
#define CONFIG_LWIP_DHCP_COARSE_TIMER 0
* NO_SYS==1: Provides VERY minimal functionality. Otherwise,
* use lwIP facilities.
#define NO_SYS 0
#ifndef CONFIG_DYNAMIC_TICKLESS
#define CONFIG_DYNAMIC_TICKLESS 0
//Enlarge SKB buffer number
#define MAX_SKB_BUF_NUM 1024
/* ---------- Memory options ---------- */
/* MEM_ALIGNMENT: should be set to the alignment of the CPU for which
lwIP is compiled. 4 byte alignment -> define MEM_ALIGNMENT to 4, 2
byte alignment -> define MEM_ALIGNMENT to 2. */
#define MEM_ALIGNMENT 4
/* MEM_SIZE: the size of the heap memory. If the application will send
a lot of data that needs to be copied, this should be set high. */
#define MEM_SIZE (64*1024)
/* MEMP_NUM_PBUF: the number of memp struct pbufs. If the application
sends a lot of data out of ROM (or other static memory), this
#define MEMP_NUM_PBUF 100
/* MEMP_NUM_UDP_PCB: the number of UDP protocol control blocks. One
per active UDP "connection". */
#define MEMP_NUM_UDP_PCB 6
/* MEMP_NUM_TCP_PCB: the number of simulatenously active TCP
connections. */
#define MEMP_NUM_TCP_PCB 10
/* MEMP_NUM_TCP_PCB_LISTEN: the number of listening TCP
connections. */
#define MEMP_NUM_TCP_PCB_LISTEN 10
/* MEMP_NUM_TCP_SEG: the number of simultaneously queued TCP
segments. */
#define MEMP_NUM_TCP_SEG 20
/* MEMP_NUM_SYS_TIMEOUT: the number of simulateously active
timeouts. */
#define MEMP_NUM_SYS_TIMEOUT 10
#define MEMP_NUM_NETCONN 8
/* ---------- Pbuf options ---------- */
/* PBUF_POOL_SIZE: the number of buffers in the pbuf pool. */
#define PBUF_POOL_SIZE 60
/* IP_REASS_MAX_PBUFS: Total maximum amount of pbufs waiting to be reassembled.*/
#define IP_REASS_MAX_PBUFS 60 //10
/* PBUF_POOL_BUFSIZE: the size of each pbuf in the pbuf pool. */
#define PBUF_POOL_BUFSIZE 1500 //508
/* ---------- TCP options ---------- */
#define LWIP_TCP 1
#define TCP_TTL 255
/* Controls if TCP should queue segments that arrive out of
order. Define to 0 if your device is low on memory. */
#define TCP_QUEUE_OOSEQ 1
/* TCP Maximum segment size. */
#define TCP_MSS (1500 - 40) /* TCP_MSS = (Ethernet MTU - IP header size - TCP header size) */
/* TCP sender buffer space (bytes). */
#define TCP_SND_BUF (10*TCP_MSS) //(5*TCP_MSS)
/* TCP_SND_QUEUELEN: TCP sender buffer space (pbufs). This must be at least
as much as (2 * TCP_SND_BUF/TCP_MSS) for things to work. */
#define TCP_SND_QUEUELEN (4* TCP_SND_BUF/TCP_MSS)
/* TCP receive window. */
#define TCP_WND (4*TCP_MSS) // (2*TCP_MSS)
/* ---------- ICMP options ---------- */
#define LWIP_ICMP 1
/* ---------- ARP options ----------- */
#define LWIP_ARP 1
/* ---------- DHCP options ---------- */
/* Define LWIP_DHCP to 1 if you want DHCP configuration of
interfaces. DHCP is not implemented in lwIP 0.5.1, however, so
turning this on does currently not work. */
#define LWIP_DHCP 1
/* ---------- UDP options ---------- */
#define LWIP_UDP 1
#define UDP_TTL 255
/* ---------- DNS options ---------- */
#define LWIP_DNS 1
/* ---------- UPNP options --------- */
#define LWIP_UPNP 0
/* ---------- SO_SNDRCVTIMEO_NONSTANDARD options --------- */
#define LWIP_SO_SNDRCVTIMEO_NONSTANDARD 1
/* ---------- SO_REUSE options --------- */
#define SO_REUSE 1
/* Support Multicast */
#define LWIP_IGMP 1
#define LWIP_RAND() rand()
extern unsigned int sys_now(void);
#define LWIP_SRAND() srand(sys_now())
#define LWIP_MTU_ADJUST 1
/* Support TCP Keepalive */
#define LWIP_TCP_KEEPALIVE 1
#if defined(CONFIG_VIDEO_APPLICATION) && CONFIG_VIDEO_APPLICATION
#undef LWIP_WND_SCALE
#define LWIP_WND_SCALE 1
#undef TCP_RCV_SCALE
#define TCP_RCV_SCALE 1
#undef MEM_SIZE
#define MEM_SIZE (512*1024)
#undef PBUF_POOL_SIZE
#define PBUF_POOL_SIZE 880
#undef MEMP_NUM_NETBUF
#define MEMP_NUM_NETBUF 60
#undef IP_REASS_MAX_PBUFS
#define IP_REASS_MAX_PBUFS 40
#undef TCP_SND_BUF
#define TCP_SND_BUF (80*TCP_MSS)
#undef TCP_SND_QUEUELEN
#define TCP_SND_QUEUELEN (6*TCP_SND_BUF/TCP_MSS)
#undef MEMP_NUM_TCP_SEG
#define MEMP_NUM_TCP_SEG TCP_SND_QUEUELEN
#undef TCP_WND
#define TCP_WND (80*TCP_MSS)
#undef MEMP_NUM_NETCONN
#define MEMP_NUM_NETCONN 64
#undef MEMP_NUM_UDP_PCB
#define MEMP_NUM_UDP_PCB MEMP_NUM_NETCONN
#undef MEMP_NUM_TCP_PCB
#define MEMP_NUM_TCP_PCB MEMP_NUM_NETCONN
#undef MEMP_NUM_TCP_PCB_LISTEN
#define MEMP_NUM_TCP_PCB_LISTEN MEMP_NUM_NETCONN
#undef LWIP_SO_SNDTIMEO
#define LWIP_SO_SNDTIMEO 1
/* ---------- Statistics options ---------- */
#define LWIP_STATS 0
#undef LWIP_PROVIDE_ERRNO
#ifndef _SYS_ERRNO_H_
#define LWIP_ERRNO_INCLUDE <sys/errno.h>
#else
#undef LWIP_ERRNO_INCLUDE
---------- Checksum options ----------
Certain platform allows computing and verifying the IP, UDP, TCP and ICMP checksums by hardware:
- To use this feature let the following define uncommented.
- To disable it and process by CPU comment the the checksum.
//Do checksum by lwip - WLAN nic does not support Checksum offload
//#define CHECKSUM_BY_HARDWARE
/* CHECKSUM_GEN_IP==1: Generate checksums in software for outgoing IP packets.*/
#define CHECKSUM_GEN_IP 1
/* CHECKSUM_GEN_UDP==1: Generate checksums in software for outgoing UDP packets.*/
#define CHECKSUM_GEN_UDP 1
/* CHECKSUM_GEN_TCP==1: Generate checksums in software for outgoing TCP packets.*/
#define CHECKSUM_GEN_TCP 1
/* CHECKSUM_CHECK_IP==1: Check checksums in software for incoming IP packets.*/
#define CHECKSUM_CHECK_IP 1
/* CHECKSUM_CHECK_UDP==1: Check checksums in software for incoming UDP packets.*/
#define CHECKSUM_CHECK_UDP 1
/* CHECKSUM_CHECK_TCP==1: Check checksums in software for incoming TCP packets.*/
#define CHECKSUM_CHECK_TCP 1
---------- Sequential layer options ----------
* LWIP_NETCONN==1: Enable Netconn API (require to use api_lib.c)
#define LWIP_NETCONN 1
---------- Socket options ----------
* LWIP_SOCKET==1: Enable Socket API (require to use sockets.c)
#define LWIP_SOCKET 1
---------- DEBUG options ----------
#define LWIP_DEBUG 0
---------- OS options ----------
#define TCPIP_THREAD_STACKSIZE 1000
#define TCPIP_MBOX_SIZE 600
#define DEFAULT_UDP_RECVMBOX_SIZE 600
#define DEFAULT_TCP_RECVMBOX_SIZE 600
#define DEFAULT_RAW_RECVMBOX_SIZE 600
#define DEFAULT_ACCEPTMBOX_SIZE 600
#define DEFAULT_THREAD_STACKSIZE 1000
//#define TCPIP_THREAD_PRIO (configMAX_PRIORITIES - 2)
#define TCPIP_THREAD_PRIO (2)
#define ETHARP_SUPPORT_STATIC_ENTRIES 1
#define LWIP_RANDOMIZE_INITIAL_LOCAL_PORTS 1
#define LWIP_DNS_LEGACY_SUPPORT 0
#define LWIP_ICMP_SUPPRESS 0
#define LWIP_ICMP_SUPPRESS_INTERVAL 900 // allow one icmp per second with tolerance of 100 ms
/* Extra options for lwip_v2.0.2 which should not affect lwip_v1.4.1 */
#define LWIP_TCPIP_CORE_LOCKING 1
#define LWIP_COMPAT_MUTEX_ALLOWED 1 // mycode: enable with core locking
#define LWIP_TCPIP_TIMEOUT 1
#define LWIP_SO_RCVTIMEO 1
#define LWIP_SOCKET_SET_ERRNO 0
#undef LWIP_DEBUG
#define LWIP_RAW 1
#define LWIP_AUTOIP 1
#define TCPIP_THREAD_NAME "TCP_IP"
#define LWIP_IPV6 1
#if LWIP_IPV6
#undef MEMP_NUM_SYS_TIMEOUT
#define MEMP_NUM_SYS_TIMEOUT 13
#ifndef CONFIG_EXAMPLE_COAP_SERVER
#define CONFIG_EXAMPLE_COAP_SERVER 0
#ifndef CONFIG_EXAMPLE_COAP_CLIENT
#define CONFIG_EXAMPLE_COAP_CLIENT 0
#include "lwip/init.h" //for version control
#undef ERRNO
#define ERRNO 1
#undef LWIP_SOCKET_SET_ERRNO
#define LWIP_SOCKET_SET_ERRNO 1
#endif /* LWIP_HDR_LWIPOPTS_H */
