I am using EVK1100 board with Win7 + ICE3 + Atmel studio 6. For some reason the FreeRTOS lwIP example does not work properly. I am not able to connect to the board. Could the problem be in router too? I also tried the lwIP + DHCP example and problem is still valid. In that example when I connect the cable between router and EVK1100, display shows that “DHCP started” but that is it.
