hermarcel wrote on Monday, August 05, 2013:
After asking some questions on this forum, I felt it was time to contribute a little.
I am running lwIP on FreeRTOS and was building an application that should block on a combination of FreeRTOS queues and lwIP sockets. After realizing that the lwIP socket-api is based on FreeRTOS queues, I came up with the following.
xQueueHandle lwip_GetAcceptQ(int s)
// Add these functions to the end of lwIP's sockets.c
// Get FreeRTOS handle of accept queue
xQueueHandle xQueue = NULL;
struct lwip_sock *sock;
sock = tryget_socket(s);
if((sock != NULL) && (sock->conn != NULL))
xQueue = sock->conn->acceptmbox;
return(xQueue);
xQueueHandle lwip_GetRecvQ(int s)
// Get FreeRTOS handle of receive queue
xQueue = sock->conn->recvmbox;
return(xQueue);
int lwip_DataInRecvQ(int s)
// Return 1 (TRUE) if there is data in the socket receive pbuf(s),
// 0 (FALSE) otherwise
int iReturn = 0;
iReturn = (sock->lastdata != NULL);
return(iReturn);
These functions return the queue handles that are (exclusively) used by lwIP for the given socket. Having the queue-id, one can simply add it to a queue set.
One note: use the lwip_DataInRecvQ(s) function to check is there is data available in the local socket buffers. This data must be read before attempting to block on the socket receive queue.
