LWIP: Add a new ethernet type although lwIP does not use this
Hello everyone,
I am interested to add ETHTYPE_PTP into the function ethernet_input(), I am working in Stm32Cube, is there a method to add this ethernet frame type ? maybe changing a flag in the .ioc file? or It can and must be done using the LWIP_HOOK_UNKNOWN_ETH_PROTOCOL(p, netif)?
err_t
ethernet_input(struct pbuf *p, struct netif *netif)
  struct eth_hdr *ethhdr;
  u16_t type;
#if LWIP_ARP || ETHARP_SUPPORT_VLAN || LWIP_IPV6
  u16_t next_hdr_offset = SIZEOF_ETH_HDR;
#endif /* LWIP_ARP || ETHARP_SUPPORT_VLAN */
  LWIP_ASSERT_CORE_LOCKED();
  if (p->len <= SIZEOF_ETH_HDR) {
    /* a packet with only an ethernet header (or less) is not valid for us */
    ETHARP_STATS_INC(etharp.proterr);
    ETHARP_STATS_INC(etharp.drop);
    MIB2_STATS_NETIF_INC(netif, ifinerrors);
    goto free_and_return;
  if (p->if_idx == NETIF_NO_INDEX) {
    p->if_idx = netif_get_index(netif);
  /* points to packet payload, which starts with an Ethernet header */
  ethhdr = (struct eth_hdr *)p->payload;
  LWIP_DEBUGF(ETHARP_DEBUG | LWIP_DBG_TRACE,
              ("ethernet_input: dest:%"X8_F":%"X8_F":%"X8_F":%"X8_F":%"X8_F":%"X8_F", src:%"X8_F":%"X8_F":%"X8_F":%"X8_F":%"X8_F":%"X8_F", type:%"X16_F"\n",
               (unsigned char)ethhdr->dest.addr[0], (unsigned char)ethhdr->dest.addr[1], (unsigned char)ethhdr->dest.addr[2],
               (unsigned char)ethhdr->dest.addr[3], (unsigned char)ethhdr->dest.addr[4], (unsigned char)ethhdr->dest.addr[5],
               (unsigned char)ethhdr->src.addr[0],  (unsigned char)ethhdr->src.addr[1],  (unsigned char)ethhdr->src.addr[2],
               (unsigned char)ethhdr->src.addr[3],  (unsigned char)ethhdr->src.addr[4],  (unsigned char)ethhdr->src.addr[5],
               lwip_htons(ethhdr->type)));
  type = ethhdr->type;
#if ETHARP_SUPPORT_VLAN
  if (type == PP_HTONS(ETHTYPE_VLAN)) {
    struct eth_vlan_hdr *vlan = (struct eth_vlan_hdr *)(((char *)ethhdr) + SIZEOF_ETH_HDR);
    next_hdr_offset = SIZEOF_ETH_HDR + SIZEOF_VLAN_HDR;
    if (p->len <= SIZEOF_ETH_HDR + SIZEOF_VLAN_HDR) {
      /* a packet with only an ethernet/vlan header (or less) is not valid for us */
#if defined(LWIP_HOOK_VLAN_CHECK) || defined(ETHARP_VLAN_CHECK) || defined(ETHARP_VLAN_CHECK_FN) /* if not, allow all VLANs */
#ifdef LWIP_HOOK_VLAN_CHECK
    if (!LWIP_HOOK_VLAN_CHECK(netif, ethhdr, vlan)) {
#elif defined(ETHARP_VLAN_CHECK_FN)
    if (!ETHARP_VLAN_CHECK_FN(ethhdr, vlan)) {
#elif defined(ETHARP_VLAN_CHECK)
    if (VLAN_ID(vlan) != ETHARP_VLAN_CHECK) {
      /* silently ignore this packet: not for our VLAN */
      pbuf_free(p);
      return ERR_OK;
#endif /* defined(LWIP_HOOK_VLAN_CHECK) || defined(ETHARP_VLAN_CHECK) || defined(ETHARP_VLAN_CHECK_FN) */
    type = vlan->tpid;
#endif /* ETHARP_SUPPORT_VLAN */
#if LWIP_ARP_FILTER_NETIF
  netif = LWIP_ARP_FILTER_NETIF_FN(p, netif, lwip_htons(type));
#endif /* LWIP_ARP_FILTER_NETIF*/
  if (ethhdr->dest.addr[0] & 1) {
    /* this might be a multicast or broadcast packet */
    if (ethhdr->dest.addr[0] == LL_IP4_MULTICAST_ADDR_0) {
#if LWIP_IPV4
      if ((ethhdr->dest.addr[1] == LL_IP4_MULTICAST_ADDR_1) &&
          (ethhdr->dest.addr[2] == LL_IP4_MULTICAST_ADDR_2)) {
        /* mark the pbuf as link-layer multicast */
        p->flags |= PBUF_FLAG_LLMCAST;
#endif /* LWIP_IPV4 */
#if LWIP_IPV6
    else if ((ethhdr->dest.addr[0] == LL_IP6_MULTICAST_ADDR_0) &&
             (ethhdr->dest.addr[1] == LL_IP6_MULTICAST_ADDR_1)) {
#endif /* LWIP_IPV6 */
    else if (eth_addr_cmp(&ethhdr->dest, &ethbroadcast)) {
      /* mark the pbuf as link-layer broadcast */
      p->flags |= PBUF_FLAG_LLBCAST;
  switch (type) {
#if LWIP_IPV4 && LWIP_ARP
    /* IP packet? */
    case PP_HTONS(ETHTYPE_IP):
      if (!(netif->flags & NETIF_FLAG_ETHARP)) {
      /* skip Ethernet header (min. size checked above) */
      if (pbuf_remove_header(p, next_hdr_offset)) {
        LWIP_DEBUGF(ETHARP_DEBUG | LWIP_DBG_TRACE | LWIP_DBG_LEVEL_WARNING,
                    ("ethernet_input: IPv4 packet dropped, too short (%"U16_F"/%"U16_F")\n",
                     p->tot_len, next_hdr_offset));
        LWIP_DEBUGF(ETHARP_DEBUG | LWIP_DBG_TRACE, ("Can't move over header in packet"));
      } else {
        /* pass to IP layer */
        ip4_input(p, netif);
      break;
    case PP_HTONS(ETHTYPE_ARP):
                    ("ethernet_input: ARP response packet dropped, too short (%"U16_F"/%"U16_F")\n",
        ETHARP_STATS_INC(etharp.lenerr);
      } else {
        /* pass p to ARP module */
        etharp_input(p, netif);
      break;
#endif /* LWIP_IPV4 && LWIP_ARP */
#if PPPOE_SUPPORT
    case PP_HTONS(ETHTYPE_PPPOEDISC): /* PPP Over Ethernet Discovery Stage */
      pppoe_disc_input(netif, p);
      break;
    case PP_HTONS(ETHTYPE_PPPOE): /* PPP Over Ethernet Session Stage */
      pppoe_data_input(netif, p);
      break;
#endif /* PPPOE_SUPPORT */
#if LWIP_IPV6
    case PP_HTONS(ETHTYPE_IPV6): /* IPv6 */
      /* skip Ethernet header */
      if ((p->len < next_hdr_offset) || pbuf_remove_header(p, next_hdr_offset)) {
                    ("ethernet_input: IPv6 packet dropped, too short (%"U16_F"/%"U16_F")\n",
      } else {
        /* pass to IPv6 layer */
        ip6_input(p, netif);
      break;
    default:
#ifdef LWIP_HOOK_UNKNOWN_ETH_PROTOCOL
      if (LWIP_HOOK_UNKNOWN_ETH_PROTOCOL(p, netif) == ERR_OK) {
        break;
      MIB2_STATS_NETIF_INC(netif, ifinunknownprotos);
  /* This means the pbuf is freed or consumed,
     so the caller doesn't have to free it again */
  return ERR_OK;
free_and_return:
  pbuf_free(p);
  return ERR_OK;
Also there are more eth types that are not included in the original code as in the file ieee.h
 * @ingroup ieee
 * A list of often ethtypes (although lwIP does not use all of them).
enum lwip_ieee_eth_type {
  /** Internet protocol v4 */
  ETHTYPE_IP        = 0x0800U,
  /** Address resolution protocol */
  ETHTYPE_ARP       = 0x0806U,
  /** Wake on lan */
  ETHTYPE_WOL       = 0x0842U,
  /** RARP */
  ETHTYPE_RARP      = 0x8035U,
  /** Virtual local area network */
  ETHTYPE_VLAN      = 0x8100U,
  /** Internet protocol v6 */
  ETHTYPE_IPV6      = 0x86DDU,
  /** PPP Over Ethernet Discovery Stage */
  ETHTYPE_PPPOEDISC = 0x8863U,
  /** PPP Over Ethernet Session Stage */
  ETHTYPE_PPPOE     = 0x8864U,
  /** Jumbo Frames */
  ETHTYPE_JUMBO     = 0x8870U,
  /** Process field network */
  ETHTYPE_PROFINET  = 0x8892U,
  /** Ethernet for control automation technology */
  ETHTYPE_ETHERCAT  = 0x88A4U,
  /** Link layer discovery protocol */
  ETHTYPE_LLDP      = 0x88CCU,
  /** Serial real-time communication system */
  ETHTYPE_SERCOS    = 0x88CDU,
  /** Media redundancy protocol */
  ETHTYPE_MRP       = 0x88E3U,
  /** Precision time protocol */
  ETHTYPE_PTP       = 0x88F7U,
  /** Q-in-Q, 802.1ad */
  ETHTYPE_QINQ      = 0x9100U
Thanks in advance,
Hi @JCesar,
This question seems geared towards LWIP on an ST device, neither of which is developed by the FreeRTOS team.
Perhaps this question would be better answered on the ST forums.
Best,
Jason Carroll
Hi @jasonpcarroll , about adding new ethernet types in LWIP doesn’t depend on which architecture. Actually, I wanted to know about experiences from other people. By now I’ll define the LWIP_HOOK_UNKNOWN_ETH_PROTOCOL(p, netif) function, It seems to me that it is the cleanest way to do it
Within FreeRTOS+TCP, only three type of Ethernet frames are handled:
	#define ipARP_FRAME_TYPE				( 0x0608U )
	#define ipIPv4_FRAME_TYPE				( 0x0008U )
	#define ipIPv6_FRAME_TYPE				( 0xDD86U )
which is ARP, IPv4, and IPv6. Users are free to add new types and have them handled by user code. See ipconfigPROCESS_CUSTOM_ETHERNET_FRAMES.
Within lwIP, apparently you can define a function LWIP_HOOK_UNKNOWN_ETH_PROTOCOL(p, netif), also to handle an unknown frame type in user code. But in most cases, the macro will not be used.
Regards
