Did anyone already made a port for the NXP LPC2478.
I was trying to do so using Rowley CrossWorks v2.0, project builds but when debugging it seems that the processor always ends up at:
I’ve tried to debug and noticed that the processor calls the abort handler when the following instruction “SUBS PC, LR, #4” is called in the function “portRESTORE_CONTEXT”.
Does anybody have an idea??
Thanks
Make sure the processor is in Supervisor mode before that line is executed. Best to use the start up files from from the FreeRTOS download that set Supervisor mode before calling main.
You where right, added the following to the preprocessor defenitions:
GCC_ARM7
SUPERVISOR_START
VECTORED_IRQ_INTERRUPTS
PACK_STRUCT_END=__attribute__((packed))
ALIGN_STRUCT_END=__attribute__((aligned(4)))
