I have been trying to implement virtual com port using lpc2387. I started with lpc code bunlde for keil .It works fine there.
But,when I try to do the same with Free rtos had no success.I found that my usb isr is not getting called. I have tried writing ISR handlers as per the demo code but no success.
…in which case you may find the USB stack is the same one use as in this project. If so you can use it as a reference for your project as, although it is running on an LPC chip, it is a Cortex-M chip rather than an ARM7.
You can convert the Cortex-M version to your chip, find one on the Internet, get one from NXP, … or purchase a commercial USB stack (in which case you would require OpenRTOS rather than FreeRTOS).
