frankandersen wrote on Thursday, March 01, 2012:
I am trying to find out why my project ends up in vListInsert:
/* *** NOTE ***********************************************************
If you find your application is crashing here then likely causes are:
1) Stack overflow -
see http://www.freertos.org/Stacks-and-stack-overflow-checking.html
2) Incorrect interrupt priority assignment, especially on Cortex M3
parts where numerically high priority values denote low actual
interrupt priories, which can seem counter intuitive. See
configMAX_SYSCALL_INTERRUPT_PRIORITY on http://www.freertos.org/a00110.html
3) Calling an API function from within a critical section or when
the scheduler is suspended.
4) Using a queue or semaphore before it has been initialised or
before the scheduler has been started (are interrupts firing
before vTaskStartScheduler() has been called?).
See http://www.freertos.org/FAQHelp.html for more tips.
for( pxIterator = ( xListItem * ) &( pxList->xListEnd ); pxIterator->pxNext->xItemValue <= xValueOfInsertion; pxIterator = pxIterator->pxNext )
/* There is nothing to do here, we are just iterating to the
wanted insertion position. */
To me it looks like the Systick interrupts preempts the USB interrupt:
In FreeRTOSConfig I have:
/* Use the system definition, if there is one */
#ifdef __NVIC_PRIO_BITS
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 5 /* 32 priority levels */
/* The lowest priority. */
#define configKERNEL_INTERRUPT_PRIORITY ( 31 << (8 - configPRIO_BITS) )
/* Priority 5, or 160 as only the top three bits are implemented. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( 5 << (8 - configPRIO_BITS) )
/* Priorities passed to NVIC_SetPriority() do not require shifting as the
function does the shifting itself. Note these priorities need to be equal to
or lower than configMAX_SYSCALL_INTERRUPT_PRIORITY - therefore the numeric
value needs to be equal to or greater than 5 (on the Cortex M3 the lower the
numeric value the higher the interrupt priority). */
#define configDMA_INTERRUPT_PRIORITY 5
#define configUSB_INTERRUPT_PRIORITY 6
#define configTIM1_INTERRUPT_PRIORITY 7
#define configTIM3_INTERRUPT_PRIORITY 8
#define configLCD_INTERRUPT_PRIORITY 4
#define configGPIO_INTERRUPT_PRIORITY 10
And in SHPR2 the value is 0xF8F80000, which I belive is the lowest priority?
How is priority between the peripherals interrupts and system interrupts?
I have a pin toggling in the TICK_HOOK and a pin in the USB it handler, when the system crashes the USB interrupt is Active and then the TICK_HOOK is called.
Any Ideas?
Best regards,
Frank Andersen
