xujingyixing wrote on Thursday, May 31, 2012:
Hi!
I’m trying to get FreeRTOS running on a LPC1778 but have not succeeded so far. I’m using version 7.1.0 and the portable for the ARM_CM3.
The code seems to run fine until vPortStartFirstTask. Stepping through the assembler instructions I get to “svc 0” after which a hard fault occurs.
vPortStartFirstTask
/* Use the NVIC offset register to locate the stack. */
ldr r0, =0xE000ED08
ldr r0,
ldr r0,
/* Set the msp back to the start of the stack. */
msr msp, r0
/* Call SVC to start the first task. */
cpsie i
svc 0
I’v added the following lines to FreeRTOSConfig.h
There is still a Hard Fault. Is there anything I have to modify more to get it running?
Sincerely,
XUJING
