Hello, there is a question: I be using Free-RTos and have created a task to iniciate Uart on 115200 baud rate, but however all I do on configurations registers can´t get right baud rate. For example, if I initiate Uart on 115200 I get 4800 on the terminal. I tried to implement the DLM and DLL starting a example code from hoan’s blog, but nothing works on Free-Rtos, without Free-Rtos works normally. Can someone help me on this simple problem?
Using Keil, FreeRTOS V6.1.0 and NPX LPC1768 microcontroller
Your UART implementation generally falls outside of FreeRTOS. Probably where you might be getting stuck is initiating the UART in a task. Have you tried initialising UART in your ‘main’ before creating your tasks and then using the UART in your tasks? I have not tried out 115200 on my LPC1768 based board, I work on 38400. But ideally if your UART works , theres no reason it should not work on FreeRTOS. Have you tried using the CMSIS libraries, makes your life far easier?
Have you verified if your tasks are running properly on FreeRTOS? Are you on the Keil simulator or on a real hardware?
Finally I get my project running. I followed your tips and had my LPC1768 running properly. All I done was starting of zero adding each kernel library from my working start project and then putting the UART_Init function before the tasks.
My Keil are simulating on a real hardware. Thank you very much.
