stodd67 wrote on Monday, November 18, 2019:
Hello all,
I’ll keep this as short as I can. I will leave out a lot of detail for now.
Hardware : STM32L071
Software : freeRTOS kernal with FAT FS.
SD card driver : bespoke SPI driver
I am developing an application to write/read to/from an SD card. I can successfully read/write to an SD card. When a do a logic grab there is a long period of 18 seconds of continously writing to the SD card. This occurs about every 5-6 hours. I have looked through the FAT FS code, but can’t find any obvious reason why this would happen. My application needs to use a watchdog timer and this long period of a task activity will cause it to reset the system.
Is this type of period normal? Is there any thing I can do to reduce it?
As stated above, it all works, but this long period is an issue for me.
Thanks,
Stephen.
