I’m not sure what these libs do and there is too much code to look
through - I would say though if they are designed to run on Linux and
make Linux system calls they are not going to run on FreeRTOS.
Thanks for the reply.
Yeah the code contains fopen, ioctls, open,close and socket calls.
So that confirms the code can be run on FreeRTOS, correct??
Thanks for your time.
No, that confirms it cannot be run on FreeRTOS, although Amazon FreeRTOS
has a POSIX threading wrapper for FreeRTOS that will soon be part of the
FreeRTOS kernel download which may help.
