nobody wrote on Friday, December 09, 2005:
Hello Richard,
In the code - it’s obvious that you run LINT on the files - can you please share your setup? Command line options, any config files, etc.
Thanks!
John W.
Hello Richard,
Thanks!
John W.
rtel wrote on Friday, December 09, 2005:
Lint was used on the original code - but as the number of compilers the code is built with grew it became very difficult to maintain its use. It is one of the many things on the todo list at the moment to replace the old lint setup with something more manageable.
John - I am hoping to contact you over the next week or two with some info.
