nobody wrote on Wednesday, January 04, 2006:
Hi
I’m trying to cross-compile on a Linux box using arm-linux-gcc v3.4.5.
This compiler compiles uClinux-2.4 without error but all of the ARM7 Demos fail linking with the output …
collect2: ld terminated with signal 11 [Segmentation fault]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .dynamic [00000000 -> 0000009f] overlaps section startup [00000000 -> 00000043]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .got.plt [000000a0 -> 000000bf] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .interp [000000a0 -> 000000b2] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .gnu.version [000000b4 -> 000000bf] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .gnu.version_r [000000c0 -> 000000df] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .dynsym [000000e0 -> 0000013f] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .dynstr [00000140 -> 00000178] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .hash [0000017c -> 000001a7] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .rel.dyn [000001a8 -> 000001cf] overlaps section prog [00000044 -> 00003f4f]
/usr/arm/lib/gcc/arm-linux/3.4.5/…/…/…/…/arm-linux/bin/ld: section .plt [000001d0 -> 0000021f] overlaps section prog [00000044 -> 00003f4f]
Does anyone know what I’m doing wrong?
