vinimac wrote on Wednesday, October 26, 2016:
Hi guys, I’m using this linker script and result xxx.bin file give 402MB. I took from CORTEX_MPU_Simulator_Keil_GCC example.
/* Specify the memory areas */
MEMORY
ROM (rx) : ORIGIN = 0x08000000, LENGTH = 512K
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 80K
/* Variables used by FreeRTOS-MPU. */
_Privileged_Functions_Region_Size = 32K;
_Privileged_Data_Region_Size = 512;
__FLASH_segment_start__ = ORIGIN( ROM );
__FLASH_segment_end__ = __FLASH_segment_start__ + LENGTH( ROM );
__privileged_functions_start__ = ORIGIN( ROM );
__privileged_functions_end__ = __privileged_functions_start__ + _Privileged_Functions_Region_Size;
__SRAM_segment_start__ = ORIGIN( RAM );
__SRAM_segment_end__ = __SRAM_segment_start__ + LENGTH( RAM );
__privileged_data_start__ = ORIGIN( RAM );
__privileged_data_end__ = ORIGIN( RAM ) + _Privileged_Data_Region_Size;
* The '__stack' definition is required by crt0, do not remove it.
__stack = ORIGIN(RAM) + LENGTH(RAM);
_estack = __stack;
* Default stack sizes.
* These are used by the startup in order to allocate stacks
* for the different modes.
__Main_Stack_Size = 2048 ;
PROVIDE ( _Main_Stack_Size = __Main_Stack_Size ) ;
__Main_Stack_Limit = __stack - __Main_Stack_Size ;
/*"PROVIDE" allows to easily override these values from an object file or the command line. */
PROVIDE ( _Main_Stack_Limit = __Main_Stack_Limit ) ;
* There will be a link error if there is not this amount of
* RAM free at the end.
_Minimum_Stack_Size = 1024 ;
* Default heap definitions.
* The heap start immediately after the last statically allocated
* .sbss/.noinit section, and extends up to the main stack limit.
PROVIDE ( _Heap_Begin = _end_noinit ) ;
PROVIDE ( _Heap_Limit = __stack - __Main_Stack_Size ) ;
* The entry point is informative, for debuggers and simulators,
* since the Cortex-M vector points to it anyway.
ENTRY(Reset_Handler)
/* Sections Definitions */
SECTIONS
* For Cortex-M devices, the beginning of the startup code is stored in
* the .isr_vector section, which goes to ROM
privileged_functions :
. = ALIGN(4);
_isr_vector = .;
KEEP(*(.isr_vector))
*(privileged_functions)
. = ALIGN(4);
/* Non privileged code is after _Privileged_Functions_Region_Size. */
__privileged_functions_actual_end__ = .;
. = _Privileged_Functions_Region_Size;
} > ROM
.text :
. = ALIGN(4);
* This section is here for convenience, to store the
* startup code at the beginning of the flash area, hoping that
* this will increase the readability of the listing.
KEEP(*(.after_vectors .after_vectors.*)) /* Startup code and ISR */
. = ALIGN(4);
* These are the old initialisation sections, intended to contain
* naked code, with the prologue/epilogue added by crti.o/crtn.o
* when linking with startup files. The standalone startup code
* currently does not run these, better use the init arrays below.
KEEP(*(.init))
KEEP(*(.fini))
. = ALIGN(4);
* The preinit code, i.e. an array of pointers to initialisation
* functions to be performed before constructors.
PROVIDE_HIDDEN (__preinit_array_start = .);
* Used to run the SystemInit() before anything else.
KEEP(*(.preinit_array_sysinit .preinit_array_sysinit.*))
* Used for other platform inits.
KEEP(*(.preinit_array_platform .preinit_array_platform.*))
* The application inits. If you need to enforce some order in
* execution, create new sections, as before.
KEEP(*(.preinit_array .preinit_array.*))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(4);
* The init code, i.e. an array of pointers to static constructors.
PROVIDE_HIDDEN (__init_array_start = .);
KEEP(*(SORT(.init_array.*)))
KEEP(*(.init_array))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(4);
* The fini code, i.e. an array of pointers to static destructors.
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP(*(SORT(.fini_array.*)))
KEEP(*(.fini_array))
PROVIDE_HIDDEN (__fini_array_end = .);
. = ALIGN(4);
. = ALIGN(4);
*(.text*) /* all remaining code */
*(vtable) /* C++ virtual tables */
} >ROM
.rodata :
*(.rodata*) /* read-only data (constants) */
} >ROM
.glue :
KEEP(*(.eh_frame*))
* Stub sections generated by the linker, to glue together
* ARM and Thumb code. .glue_7 is used for ARM code calling
* Thumb code, and .glue_7t is used for Thumb code calling
* ARM code. Apparently always generated by the linker, for some
* architectures, so better leave them here.
*(.glue_7)
*(.glue_7t)
} >ROM
/* ARM magic sections */
.ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > ROM
__exidx_start = .;
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > ROM
__exidx_end = .;
. = ALIGN(4);
_etext = .;
__etext = .;
* This address is used by the startup code to
* initialise the .data section.
_sidata = _etext;
/* MEMORY_ARRAY */
.ROarraySection :
*(.ROarraySection .ROarraySection.*)
} >MEMORY_ARRAY
privileged_data :
*(privileged_data)
/* Non kernel data is kept out of the first _Privileged_Data_Region_Size
bytes of SRAM. */
__privileged_data_actual_end__ = .;
. = _Privileged_Data_Region_Size;
} > RAM
* The initialised data section.
* The program executes knowing that the data is in the RAM
* but the loader puts the initial values in the ROM (inidata).
* It is one task of the startup to copy the initial values from
* ROM to RAM.
.data : AT ( _sidata )
. = ALIGN(4);
/* This is used by the startup code to initialise the .data section */
_sdata = . ; /* STM specific definition */
__data_start__ = . ;
*(.data_begin .data_begin.*)
*(.data .data.*)
*(.data_end .data_end.*)
. = ALIGN(4);
_edata = . ; /* STM specific definition */
__data_end__ = . ;
} >RAM
* The uninitialised data section. NOLOAD is used to avoid
* the "section `.bss' type changed to PROGBITS" warning
.bss (NOLOAD) :
. = ALIGN(4);
__bss_start__ = .; /* standard newlib definition */
_sbss = .; /* STM specific definition */
*(.bss_begin .bss_begin.*)
*(.bss .bss.*)
*(COMMON)
*(.bss_end .bss_end.*)
. = ALIGN(4);
__bss_end__ = .; /* standard newlib definition */
_ebss = . ; /* STM specific definition */
} >RAM
.noinit (NOLOAD) :
. = ALIGN(4);
_noinit = .;
*(.noinit .noinit.*)
. = ALIGN(4) ;
_end_noinit = .;
} > RAM
/* Mandatory to be word aligned, _sbrk assumes this */
PROVIDE ( end = _end_noinit ); /* was _ebss */
PROVIDE ( _end = _end_noinit );
PROVIDE ( __end = _end_noinit );
PROVIDE ( __end__ = _end_noinit );
PROVIDE ( ROM_DATA_START = __data_start__ );
* Used for validation only, do not allocate anything here!
* This is just to check that there is enough RAM left for the Main
* stack. It should generate an error if it's full.
._check_stack :
. = ALIGN(4);
. = . + _Minimum_Stack_Size ;
. = ALIGN(4);
} >RAM
/* After that there are only debugging sections. */
/* This can remove the debugging information from the standard libraries */
DISCARD :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
/* Stabs debugging sections. */
.stab 0 : { *(.stab) }
.stabstr 0 : { *(.stabstr) }
.stab.excl 0 : { *(.stab.excl) }
.stab.exclstr 0 : { *(.stab.exclstr) }
.stab.index 0 : { *(.stab.index) }
.stab.indexstr 0 : { *(.stab.indexstr) }
.comment 0 : { *(.comment) }
* DWARF debug sections.
* Symbols in the DWARF debugging sections are relative to the beginning
* of the section so we begin them at 0.
/* DWARF 1 */
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
/* GNU DWARF 1 extensions */
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
/* DWARF 1.1 and DWARF 2 */
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
/* DWARF 2 */
.debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
/* SGI/MIPS DWARF 2 extensions */
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
Does anyone have a working Linker Script for the STM32 family and the MPU-port?
Or an explanation for the behavior?
