nobody wrote on Tuesday, October 17, 2006:
I am using CodeSourcery’s GCC 4.1.0 compiler to do a port to an ARM7TDMI-based system. So I took the ARM7_LPC2106_GCC port and am in the process of modifying. I am trying to compile after some mods and I get a linker error:
arm-none-eabi/bin/ld: region ram is full (rtosdemo.elf section .bss)
Not sure why this is happening, especially since my board has 4MB of RAM. I have modified the linker script to reflect the increased RAM but otherwise left it as it was:
MEMORY
flash : ORIGIN = 0, LENGTH = 512K
ram : ORIGIN = 0xc0000000, LENGTH = 4M
__stack_end__ = 0xc0000000 + 4M - 4;
SECTIONS
. = 0;
startup : { *(.startup)} >ram
prog :
*(.text)
*(.rodata)
*(.rodata*)
*(.glue_7)
*(.glue_7t)
} >ram
__end_of_text__ = .;
.data :
__data_beg__ = .;
__data_beg_src__ = __end_of_text__;
*(.data)
__data_end__ = .;
} >ram
.bss :
__bss_beg__ = .;
*(.bss)
} >ram
/* Align here to ensure that the .bss section occupies space up to
_end. Align after .bss to ensure correct alignment even if the
.bss section disappears because there are no input sections. */
. = ALIGN(32 / 8);
. = ALIGN(32 / 8);
_end = .;
_bss_end__ = . ; __bss_end__ = . ; __end__ = . ;
PROVIDE (end = .);
In the map file, what looks shady to me is:
[snip]
.bss 0xc0006640 0x100 …/…/Source/tasks.o
0xc0006640 pxCurrentTCB
.bss 0xc0006740 0x400018 …/…/Source/portable/MemMang/heap_2.o
COMMON 0xc0406758 0x4 …/Common/Minimal/dynamic.o
0xc0406758 xSuspendedTestQueue
0xc040675c . = ALIGN (0x4)
0xc040675c _end = .
0xc040675c _bss_end__ = .
0xc040675c __bss_end__ = .
0xc040675c __end__ = .
0xc040675c PROVIDE (end, .)
OUTPUT(rtosdemo.elf elf32-littlearm)
[snip]
What’s weird is there is the line .bss 0xc0006740 0x400018 …/…/Source/portable/MemMang/heap_2.o
because after this the addresses go beyond the 4MB limit. Not sure though.
Any help is appreciated.
james
