chdo wrote on Thursday, May 30, 2013:
Am trying to flash a led of an STM32-P107, i created a freertos code, i compiled the project without having errors but there is no result on the card, This is my code :
/ Standard includes. /
include
include
/ Scheduler includes. /
include “FreeRTOS.h”
include “task.h”
include “queue.h”
include “semphr.h”
include “leds.h”
include “button.h”
include “stm32f10x_conf.h”
include “stm32_eval.h”
include “partest.h”
/ Task priorities. /
define mainFLASH_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
define TASKPRIORITY1 (tskIDLE_PRIORITY + 1)
define TASKPRIORITY2 (tskIDLE_PRIORITY + 2)
define TASKPRIORITY3 (tskIDLE_PRIORITY + 3)
/ The rate at which the flash task toggles the LED. /
define mainFLASH_DELAY ( ( portTickType ) 25 / portTICK_RATE_MS )
/ The number of nano seconds between each processor clock. /
define mainNS_PER_CLOCK ( ( unsigned portLONG ) ( ( 1.0 / ( double ) configCPU_CLOCK_HZ ) * 1000000000.0 ) )
* Configure the clocks, GPIO and other peripherals as required by the demo.
static void prvSetupHardware(void);
* The LCD is written two by more than one task so is controlled by a
* ‘gatekeeper’ task. This is the only task that is actually permitted to
* access the LCD directly. Other tasks wanting to display a message send
* the message to the gatekeeper.
extern int sprintf(char out, const char format, …);
xTaskHandle xTaskLed;
void vTaskFunction( void * pvParameters );
//void vTaskLed( void *pvParameters );
int main(void) {
prvSetupHardware();
setbuf(stdout,NULL);
/* Start the scheduler. */
printf("########################## MINI PROJET CS530 ################\\n");
ButtonInit();
LEDsInit();
xTaskCreate(vTaskFunction,“vTaskFunction”, configMINIMAL_STACK_SIZE+50 , NULL, TASKPRIORITY1,NULL);
// xTaskCreate( vTaskLed, “vTaskLed”, configMINIMAL_STACK_SIZE+50, NULL, TASKPRIORITY2, &xTaskLed );
GPIO_WriteBit( GPIOC, GPIO_Pin_6,Bit_SET );
vTaskStartScheduler();
/* Will only get here if there was not enough heap space to create the
idle task. */
return 0;
static void prvSetupHardware(void) {
USART_InitTypeDef USART_InitStructure;
/* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE and AFIO clocks */
RCC_APB2PeriphClockCmd(
RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
| RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
| RCC_APB2Periph_AFIO, ENABLE);
/* Set the Vector Table base address at 0x08000000 */
ifdef IAP_VECT_TAB_RELOCATE
NVIC_SetVectorTable(NVIC_VectTab_FLASH_RELOCATED, 0x0);
NVIC_SetVectorTable( NVIC_VectTab_FLASH, 0x0 );
endif
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
/* Configure HCLK clock as SysTick clock source. */
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
/* Configure UART */
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl= USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
STM_EVAL_COMInit(COM2, &USART_InitStructure);
const portTickType xDelay = 500 / portTICK_RATE_MS;
for( ;; )
LEDToggle(LEDG);
vTaskDelay( xDelay );
and this the led.c code:
* leds.c
* Created on: Nov 8, 2011
* Author: MMM
include “leds.h”
void LEDsInit(void)
//GPIO structure used to initialize LED port
GPIO_InitTypeDef GPIO_InitStructure;
//Enable clock on APB2 pripheral bus where LEDs are connected
RCC_APB2PeriphClockCmd(LEDPORTCLK, ENABLE);
//select pins to initialize LED
GPIO_InitStructure.GPIO_Pin = LEDG|LEDB;
//select output push-pull mode
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//highest speed available
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(LEDPORT, &GPIO_InitStructure);
void LEDToggle(uint32_t LEDn){
if(GPIO_ReadOutputDataBit(LEDPORT, LEDn)) //read previous state
GPIO_ResetBits(LEDPORT, LEDn); //set to zero
GPIO_SetBits(LEDPORT, LEDn);//set to one
what is wrong please?
