kheksel wrote on Monday, March 16, 2009:
I have problem with floating point formatting of sprintf function. Integer formatting works fine. Is there something rtos specific, I should setup?
Thanks for any clue.
Konrad
Konrad
edwards3 wrote on Monday, March 16, 2009:
Are you saying it only doesn’t work when you are using the RTOS? So in a small non RTOS APP the floating point formatting does work?
kheksel wrote on Tuesday, March 17, 2009:
It looks like…
The following line of code works with non-rtos version of application.
sprintf(CommonBuffer,"I =%5.2fA Delta =%4.1f%%\n", (float)current/100, (float)CalcDeviation(current)/10);
In rtos version of appplication formatting itself look ok, but values of formatted variables are not right (usually zeros).
Keil 3.40, FreeRTOS 5.1.2, LPC2388
Regards,
Konrad
icefishhead wrote on Tuesday, March 17, 2009:
May be it is because the sprintf() function is reenterable. I just guess.
Regards
djg wrote on Wednesday, March 18, 2009:
I had a similar problem with floating point on the FreeRTOS Luminary Stellaris demo.
The problem is the float is passed in as a 64 bit double and the ARM requires it to be aligned to 64 bits. The demo set the stack up 32 bit aligned. The changes I made to 4.7.2? using GCC were
FreeRTOS/Demo/CORTEX_LM3Sxxxx_Eclipse/RTOSDemo/startup.c
added the attribute to stack declaration to force 64 bit alignment
static unsigned long __attribute__ ((aligned (8))) pulStack[STACK_SIZE];
FreeRTOS/Source/portable/GCC/ARM_CM3/portmacro.h
changed to
#define portBYTE_ALIGNMENT 8
(I also had to add floating point printing to the supplied printf)
kheksel wrote on Wednesday, March 18, 2009:
This is the point. The problem is with passing 64 bit variable as function parameter in Task.
When, during debugging, I changed appropriately SP the sprintf function started working correctly.
I tried to setup my Keil project similarly, but unfortunately without success.
I appreciate any hints.
Konrad
I managed it running under heap_2 memory model.
The modifications should be exactly like "dig" suggested.
For Keil it is:
in portmacro.h
__align(8) static struct xRTOS_HEAP
unsigned portLONG ulDummy;
unsigned portCHAR ucHeap[ configTOTAL_HEAP_SIZE ];
} xHeap;
in heap_2.c
I am still confused in heap_3 memory model for which the problem still exists.
I checked. Configuration of heap in Startup.s file is 8 bytes aligned.
So why it does not work in this case?
konrad
