i found an example in microchip application notes (an1264) but it’s for a pic without integrated ethernet, and it uses an ethernet pictail adapter. But i need an example for the ehternet starter kit which uses the PIC32MX795F512L.So there’s only two ways for doing it, one is finding an example for this microcontroller and the other is adapting the code in the an1264 for the PIC32MX795F512L and it’s very hard since the an1264 it’s using an ethernet pictail.
The FreeRTOS Microchip Masters class is using this board http://mchp.us/MEBfreeRTOS with networking. If you search this forum for Microchip Multi Media Board, or MMB, you will find a link to some code for the board that may or may not (I’m not sure) have Ethernet included too. Plus, I am aware of at least one other project for the starter kit that will be available soon.
the point is the same, the “pic32 starter kit” it’s using a pic without ethernet port, so it needs a “pictail ethernet adapter” which is a device conected with the pic by spi. However The “pic32 ethernet starter kit” it’s using a pic with integrated ehternet port. And i haven’t found any example for that kind of pic with ehternet port which is the most usefull, since the pictail device is not the best way to implement ethernet.
And i keep wondering if it’s an example for a pic with integrated ehternet port.
