Currently I am having issues with a program running a freertos program. The purpose of the program is to control a stepper motor as well as an led. Implementing the motor control without microstepping does not have any issues as the two tasks take no parameters and call no functions.
However, when I introduce microstepping which requires two nested functions to be called by the move_routine task, the program will not do anything (no led flashing, no motor turning) when it did before. Does anyone have any solutions for this or any reasons on why this shouldn’t work? From what I can see it should be fine to call a function from a freertos task.
#include <Arduino.h>
#include <Stepper.h>
/*================PIN DEFINITIONS================*/
#define LEDC_CHANNEL_0 0
#define LEDC_CHANNEL_1 1
#define LEDC_CHANNEL_2 2
#define LEDC_CHANNEL_3 3
const int A1A = 14;
const int A1B = 27;
const int B1A = 26;
const int B2A = 25;
const int ledPin = 33;
/*================VARIABLE DEFINITIONS================*/
int stepnumber = 0;
int Pa; int Pb;
const int stepsPerRev = 200;
Stepper myStepper(stepsPerRev, 14,27,26,25);
/*================Function Definitions================*/
//Analogwrite using LEDC capabilities
void ledcAnalogWrite(uint8_t channel, uint32_t value, uint32_t valueMax = 255) {
//calculation of duty cycle
uint32_t duty = (4095/valueMax)*min(value, valueMax);
ledcWrite(channel,duty);
void move(int stepnumber, int MAXpower, int wait) {
Pa = (sin(stepnumber*0.098174)*MAXpower);
Pb = (cos(stepnumber*0.098174)*MAXpower);
if (Pa>0)
ledcAnalogWrite(LEDC_CHANNEL_0,Pa);
ledcAnalogWrite(LEDC_CHANNEL_1,0);
ledcAnalogWrite(LEDC_CHANNEL_0,0);
ledcAnalogWrite(LEDC_CHANNEL_1,abs(Pa));
if (Pb>0)
ledcAnalogWrite(LEDC_CHANNEL_2,Pb);
ledcAnalogWrite(LEDC_CHANNEL_3,0);
ledcAnalogWrite(LEDC_CHANNEL_2,0);
ledcAnalogWrite(LEDC_CHANNEL_3,abs(Pb));
void move_routine(void *parameters) {
while(1) {
for (int i=0; i<3199; i++)
stepnumber++;
move(stepnumber,255,250);
vTaskDelay(3000/portTICK_PERIOD_MS);
for (int i=0; i<1599; i++)
stepnumber--;
move(stepnumber,255,1000);
void led_task(void * parameters){
while(1){
digitalWrite(ledPin, HIGH);
vTaskDelay(500/portTICK_PERIOD_MS);
digitalWrite(ledPin, LOW);
void setup(){
myStepper.setSpeed(60);
pinMode(ledPin, OUTPUT);
Serial.begin(115200);
xTaskCreatePinnedToCore(
move_routine,
"Move Routine",
8192,
NULL,
1,
NULL,
1
led_task,
"LED Task",
1024,
NULL,
1,
NULL,
1
void loop(){
