Issue about xEventGroupClearBits()
hi,
example code below:
I def a one-shot softwaretimer ,whose period is 10000ms;
void vTimerCallBack( TimerHandle_t xTimer)
if( xTimer == xTimerHandle )
xEventGroupClearBits( xEventGroupHandle, 0x00ffffff );
at a task,I start the timer.
void vTaskA( void *pvPara )
for( ;; )
xTimerReset( xTimerHandle , 5 );
vTaskSuspend( NULL );
What I want to do is clear all bits in the EventGroup.
if the parameter set 0x00ffffff; no bad happen. it run well;
but if set 0xffffffff, start timer ,and after 10 senconds app crashed, and reset by WDT.
all helpul imformation welcome.
An event group only has 24 (or 8 if configUSE_16_BIT_TICK is set) event bits, so a clear (or set) value above 0x00FFFFFF is acting on bits that aren’t available. It shouldn’t ‘crash’, but it could have an assert on the value. If you break with a debugger at that point, is it stuck in an assert?
The reason for the upper limit is that internally FreeRTOS uses those upper bits in places to handle other information.
thanks,your words resolved it.
hi,I think these upper 8 bits limit are all 0 for now time. am i right? Has FreeRTOS use them already at some where internally until V10.
I’m not sure I understand your question - but the restrictions on which bits are used by the user and which by the kernel has not changed since the feature was introduce.
I mean for example。when calling xBits = xEventGroupGetBits( xEventGroup ); then I poll xBits, like this:
if(xBits == 0x00000010){ do something; } , because only 24bits of xBits is for user, so Should I poll xBits like
this: if( (xBits&0x00ffffff) == 0x00000010 ){do something ;}? which one is correct?
FreeRTOS will always return 0 for the upper 8 bits of the event word. It internally uses those bits in messages for manipulating events (if I remember right, for example, if an ISR posts some event bits, which is deferred to the Timer/Service task due to the unpredictable time it would take.).
