nobody wrote on Tuesday, May 10, 2005:
Hello!
I am having problems with getting the PIO interrupt to work properly. I have made a wrapping function in assembler and the interrupt is called properly, but when processor is about to leave the ISR and the portRESTORE_CONTEXT is called I get a data abort exception. Why is this?? My ISR is pasted below:
__arm void pio_ISR( void )
portCHAR cContextSwitchRequired;
int dummy;
dummy = AT91C_BASE_PIOA->PIO_ISR;
dummy=dummy; //Suppress compiler warning
//* Read the output state
if ( (AT91F_PIO_GetInput(AT91C_BASE_PIOA) & INPUT_SERVO2_CAP) == INPUT_SERVO2_CAP); //Don’t do anything, rising edge
else //Falling edge -> capture value in
measure.duty_channel_2 = TimerBaseCPWM->TC_CV;
cContextSwitchRequired = pdFALSE;
portEND_SWITCHING_ISR( ( cContextSwitchRequired ) );
/* End the interrupt in the AIC. */
AT91C_BASE_AIC->AIC_EOICR = 0;
Interrupt initialization:
AT91F_PIO_CfgInput(AT91C_BASE_PIOA, INPUT_SERVO2_CAP);
AT91F_AIC_ConfigureIt (AT91C_BASE_AIC, AT91C_ID_PIOA, PIO_INTERRUPT_LEVEL, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, ( void (*)( void ) ) pio_ISREntry);
AT91F_PIO_InterruptEnable(AT91C_BASE_PIOA, INPUT_SERVO2_CAP);
//* set the interrupt by software
AT91F_AIC_EnableIt (AT91C_BASE_AIC, AT91C_ID_PIOA);
Wrapping file:
RSEG ICODE:CODE
CODE32
EXTERN pio_ISR
PUBLIC pio_ISREntry
; Wrapper for the USB interrupt service routine. This can cause a
; context switch so requires an assembly wrapper.
; Defines the portSAVE_CONTEXT and portRESTORE_CONTEXT macros.
#include "ISR_Support.h"
pio_ISREntry:
portSAVE_CONTEXT ; Save the context of the current task.
bl pio_ISR ; Call the ISR routine.
portRESTORE_CONTEXT ; Restore the context of the current task -
; which may be different to the task that
; was interrupted.
END
Thanks in advance!
//MB
